F100 and a cab over camper
Soonersteve
Post by Soonersteve »
OK, I have a 1975 F100 4x4 shortwide. Thinking about getting a cab over camper or a pop-up 4x4 camper, but I only have about 700 lbs left in my GVWR. What would I need to do to make this happen?
New leaf-springs?
airbag system?
etc...
Thanks for taking the time and helping a guy out.
1972hiboy
Re: F100 and a cab over camper
Post by 1972hiboy »
Id go with a pop up, or something light. you dont have alot of room to work within, i would do add a leafs like hellwigs or something over air bags. air bags dont like articulation off road if sagging becomes a concern.
Rich
Dont eat yellow snow.....
Soonersteve
1972hiboy wrote:Id go with a pop up, or something light. you dont have alot of room to work within, i would do add a leafs like hellwigs or something over air bags. air bags dont like articulation off road if sagging becomes a concern.
Thanks 1972hiboy! Any suggestions on leafs, or just any old springs off a donor highboy will do?
eggman918
Post by eggman918 »
I would find a local spring shop and have them re-arch and bush your springs as needed and add the leaves needed to carry the weight you want it to :2cents:
Steve
1972hiboy
Post by 1972hiboy »
To be honest i am not sure if highboy springs would go onto a f100. I think they are a different spring. re-arcing would be the better repair. but bolt on add a leafs are an option too.
Rich
Not really the greatest host for the duty but... Up rate the sway bars, add a steering stabilizer. Re bush the springs and make sure everything it tight in the steering and it should be OK. Don't overload it and try to keep the weight down low.
I'd also do a late model EFI / 5 speed swap with discs and PS up front.
