Coil Springs
sb4boys
Coil Springs
Postby sb4boys » Mon Jul 24, 2017 2:35 pm
I just replace the coil springs, tie rods and bushings on my 68 f100, and now the driver’s side sits about an inch higher than the passenger side. Could the coil springs be side specific or is it something else?
Re: Coil Springs
Postby basketcase0302 » Thu Jul 27, 2017 4:54 am
sb4boys wrote:I just replace the coil springs, tie rods and bushings on my 68 f100, and now the driver’s side sits about an inch higher than the passenger side. Could the coil springs be side specific or is it something else?
Yes they are side specific designed that way due to the power steering weight offset. :wink:
viewtopic.php?f=22&t=46251
xanthias
Re: Coil Springs
Postby xanthias » Thu Jul 27, 2017 8:32 pm
I'm about to do this, so which side gets the taller coil?
ultraranger
Re: Coil Springs
Postby ultraranger » Fri Jul 28, 2017 7:00 am
Taller, thinner wire diameter spring goes on the left. Shorter, thicker spring goes on the right.
xanthias
Re: Coil Springs
Postby xanthias » Fri Jul 28, 2017 8:14 pm
ultraranger wrote:Taller, thinner wire diameter spring goes on the left. Shorter, thicker spring goes on the right.
Thanks! Just to be crystal, "left" = driver side in your answer, correct?
sb4boys
Re: Coil Springs
Postby sb4boys » Fri Jul 28, 2017 9:07 pm
Thanks for all the feedback. I switched the springs and it is now level..I thought they were both the same.
Re: Coil Springs
Postby basketcase0302 » Sat Jul 29, 2017 12:53 pm
:thup:
