Frozen brake line flare nut
Clunker
Postby Clunker » Sun May 28, 2017 5:41 pm
I've dealt with rusted bolts before, but this one has me stumped. I decided to replace a brake line on the F250 because I couldn't get one of the flares to seal. I got the wheel cylinder side to come loose, but the end that connects to the distribution block is totally frozen. A six point socket rounded the corners, and a very tight set of sharp vice grips just keeps shaving off layers of metal. I've used PB Blaster, and a torch. The sucker will not budge. Any suggestions?
1970 F250 CS: 360, RV cam, Edelbrock Performer 390 intake, Holley 600, headers, Pertronix II, Flamethrower coil.
Busboy
Re: Frozen brake line flare nut
Postby Busboy » Sun May 28, 2017 6:16 pm
Well its time to replace the line so just cut through it and make a new one.
1969 F-250 Camper Special, custom cab.
1967 F-100 4x4 custom cab.
2016 F-150 Eco-Boost 3.7 liter. (It will smoke the tires!)
cep62
Postby cep62 » Sun May 28, 2017 9:22 pm
Clunker wrote:A six point socket rounded the corners
Try tapping a smaller metric 6 point ( 9mm ?) on and see if that grabs.
or it might be time for a new flex line / distribution block.
Busboy
Postby Busboy » Sun May 28, 2017 10:23 pm
A small pipe wrench will remove it.
Clunker
Postby Clunker » Mon May 29, 2017 10:59 am
Ah yes! A pipe wrench. I'll give that a shot, but there is very little room between the flare nut and the axle housing. Thanks for the suggestion.
Clunker
Postby Clunker » Mon May 29, 2017 11:38 am
Pipe wrench worked. Still took a lot of force to turn it. I can't believe the nut didn't break. Thanks again.
Busboy
Postby Busboy » Mon May 29, 2017 7:33 pm
Great.
eggman918
Postby eggman918 » Mon May 29, 2017 9:54 pm
Acetone and ATF 50/50 is the best thing for stubborn rusted fasteners but you will need to shake it up before use as it tends to separate after sitting.
Steve
Ron_Hall
Postby Ron_Hall » Mon Jul 24, 2017 5:43 pm
Who is online
