Cv calipers
trick
Cv calipers
Post by trick »
Ok. I havent yet mounted the cv. I am gathering up all my parts first. My question is about the calipers. Are the brake line threads metric. If so, is there an adapter to the original equipment flex line? I would like to replace the flex line with a breaded one. Any input would be wonderfull. Thank you in advance.
Re: Cv calipers
NAPA sells conversion fittings. I just drag everything along and pick / chose what I need from the shelf. Since it's from a CV you might also be able to use a good bit of the original lines and bend them to fit the new application. I hate double flaring brake lines.
