All,
Are all wheel lugs (and lug nuts) for our trucks, regardless of year, the same threading? Is it the same for F100 vs F250 vs F350? I'm looking at converting to front disc brakes, and am wondering if the lug nuts from my drums will thread onto the disc lugs.
Lug Threading?
- colnago
Lug Threading?
- HIO Silver
Re: Lug Threading?
I recall some F-trucks were reverse-threaded.. clockwise to loosen.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: Lug Threading?
F100 wheel studs are 1/2"-20 RH thread.
- TNIceWolf
Re: Lug Threading?
The lug studs on my F350 are quite a bit larger in diameter than a half ton. They are also a mix of left and right hand threads, There are also a couple of hex sizes that can be used on the F350,
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
