F-250 4x4 steering box needle roller bearing upgrade
- eggman918
Yesterday I started the rebuild of the steering box on my '68 F-250 4x4 it's the last original component on my truck with over 750,000 miles
After tearing it down it's not surprising it lasted as long as it did it was defiantly over built the only "weak link" is the bushings on the Pittman arm shaft
but that is an easy fix,I'm replacing the bushings with Torrington needle roller bearings. Two bearings and lip seals will run about $30.00, to do this requires that a new cover is made and the bushing bore in the housing needs to be bored out ~ .062" I thing it will take about 4 hours of machining to do. The box will even clear the ways in my 10" lathe so setup is simple as long as it lasted last time this should be a "forever fix"!
I will post blow by blow pics as soon as I'm done, bearings won't be here until next week so I'll try to get pics up to the point on reassembly this weekend
Steve
- eggman918
Re: F-250 4x4 steering box needle roller bearing upgrade
Here are the pics up to the point of reassembly.
box disassembled I have two boxes and they are different internally the top on end is smaller in Dia. and longer the bottom is larger in Dia. and shorter
Steve
- eggman918
The cover wears to one side
this cover is the long shaftYou do not have the required permissions to view the files attached to this post.
Steve
- eggman918
This is the short
new cover for bearing vs the old for bushing
Steve
- eggman918
Housing in lathe ready to bore for bearing Iwas wrong before when I stated that it was .062" that needed to come out it's .125" on the Dia. so .062" on a side
the bearings are a B-228 and a B-2216 the seal is a 340853 and I plan to use two one to keep oil in and one reversed to keep crap out I tapped out a piece of cardboard to make a pattern to shape the outside of cover The end result
Steve
- eggman918
The seal # I listed earlier was wrong,it will fit but it is thicker than the ones i am using.
I am using #50480-S they are .187" thick so two should fit back to back so a lip will be facing both ways.
Steve
- eggman918
Now for reassembly, first here are the bearings they are the full compliment style i hope they will handle the loads best
next is the installation tool with the short bearing on it
the other parts clean and ready
Steve
- eggman918
next is pressing the bearings,the short one is shown as it gives the best view but it's the same for both
Here it is in the cover it's flush with the face and their is about 3/32" between bottom of bearing and bore
The long bearing is flush with the bore on the inside of case
Steve
- eggman918
Now it's time to set the position of the shaft and bearings the 1/2"-20 stud is for shaft position and thrust load. And locked in place with the jam nut.
Steve
- eggman918
installing the worm shaft is next the bottom race is still in the case
Next the balls
And the worm
Steve
- eggman918
Top balls and race
My box had 3 .010" shims so I went back with that amount of preload I would have liked a bit more preload bit .010" was too much so I left it as is I didn't have any material to make a new one.You do not have the required permissions to view the files attached to this post.
Steve
- eggman918
here the worm is in and cover is sealed and tight.
With 2-3 hours of machine shop time to bore box and machine new cover this project is easy enough that anyone could do it...........there were no surprises in it.
here the other shaft/cover are in place
here it's ready to go back in truck I added a hose to the vent to keep out water during deep crossings,all my other vents are at least 48" off the ground but I never thought about the steering box
The truck has never had as nice "feel" in the steering as it does now this project was worth the time and money With 2-3 hours of machine shop time to bore box and machine new cover this project is easy enough that anyone could do it...........there were no surprises in it.
Steve
