How to rebuild an automatic steering column - Completed
Re: How to rebuild an automatic steering column - Completed
Not removed or disassembled. About the only pic I have of it is here from when the inner collar busted.
clemsonjeep
Post by clemsonjeep »
Just followed this to replace the shift collar on my 71. Thanks for doing the writeup!!
My issues is this...I can't get the shift lever to go down into 1st gear. It engages all other gears as it should. I just wish I could see the shift gate with the shift lever installed to see what's keeping it from traveling far enough. Anyone else run into this or have any ideas?
I used a NOS part...CODZ-7228-A.
71 F100 Ranger XLT 360
Sure it's not the linkage to the transmission? Disconnect the linkage rod from the shift lever at the bottom of the column and try working the shifter, then grab the linkage rod by hand and try working the transmission. Might also want to post your issue in a fresh thread. This one's a little old.
youngone
Post by youngone »
Just did my column using this thread and it worked perfectly. I like the tip about using the rope and the one with the square bolts they both made life easier. Thanks so much for writing this procedure up. :fr:
Glad you found it helpful. :D
72Richb UK
Post by 72Richb UK »
Glad I found this thread, awesome write up and pictures.
my column is in lots of bits, took me 3 days to dismantle because the truck had sat in a field for 10 years in Oklahoma and the lower few inches had rusted and the shift lever was solid, love Evaporust now :thup:
Thanks! Sounds like you've had fun! :lol:
Grizzlyo
Post by Grizzlyo »
Thanks for the guide. Need advice, Have a c6 transmission on an f150. The automatic shifter is very sloppy. I replaced the collar, the shift tube, and the lockout bracket. The original lockout bracket screws were replaced by previous owner with pan heads that do not sit flush. I found some #8-32s that sorta fit but the head is too large. When assembled the shifter barely moves, now too tight. I can release the square retaining bolts a little but then it’s sloppy. I feel,like the linkage is half the problem. Almost ready to replace with aftermarket gm. Ant thoughts?
The screws were originally countersunk Phillips head screws. You can get them from McMaster Carr or I've had a lot of luck finding miscellaneous hardware at my local Ace Hardware store.
What kind of shape is the end of your shifter in? Did you also replace the rubber insulator on the shifter?
Another area of sloppiness is the rubber bushings in the shift levers. How does it feel without the linkage being connected to the transmission?
JWW
Post by JWW »
Thanks for posting this. The knowledge shared on here is so helpful.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
