What wheels will fit on an '02 F250?
dolinick
Post by dolinick »
Will wheels from the 1960s or 1970s fit on a 2002 F250. It is 2 wheel drive if that makes any difference. Eight lugs.
Dan
2003 7.3L F250
1968 F500 Utility Truck
dolinick
Re: What wheels will fit on an '02 F250?
Post by dolinick »
I kind of forgot this is the wrong forum for 2002 Ford Truck. :oops:
But I did find these 2007 17 inch wheels for sale that I think I like.
http://sanantonio.craigslist.org/pts/2986781604.html
2003 7.3L F250
trickf100
Post by trickf100 »
Only wheels from 99 and newer superdutys will work on your truck. They have a metric 8x170mm bolt pattern where as the older trucks had a standard 8x6.5 bolt pattern. I don't think they have changed the bolt pattern since 99 so I am fairly confident the 07 wheels will work. Good luck. I like that style of wheel myself.
1968 f100 Ranger
1972 f100 Sport Custom
1972 f250 4x4 conversion
fireguywtc
Post by fireguywtc »
Back spacing did change throughout the years on the superduty's, but only in the 4wd versions I think. I don't know enough about back spacing in the superduty's to give you a proper answer but it will be something you need to check. The bolt pattern in the superduty's is all the same though.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
dolinick
Post by dolinick »
It looks like you need a 2" spacer if you want to put '05 and up wheels on a '99-'04 Superduty. I guess you would have to really really like those wheels to do that. Spacers are expensive and there safety is questionable. I am gonna keep looking for some '99-'04 stock Ford wheels.
Dan
2003 7.3L F250
