bumps with lowered altitude!! (lots of great custom bumps!!)
rumblin46
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
Post by rumblin46 »
Smokin444 wrote:Any lwb bumps lowered with the crown vic suspension?
69 F100 - Coyote - Gen II Flavor
guhfluh
Post by guhfluh »
td wrote: Man do do you have an awesome truck!! You have one of the very few lowered crews in the entire 95 pages of this thread! Thanks for sharing it with us! :thup: O and the extra trim in the front is perfect!
Thanks td! Everybody told me not to lower it, but I just couldn't help it and I love it!
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
Freddie
Post by Freddie »
those trucks all looks great, but please can someone confirm how much they remove from the front coils when they do a half flip on the rear holder please. Another question i have is what is the best tire combination and the best offset for the rear tires. thanks.
Freddie
Post by Freddie »
what size tires and rims are you running along with your offsets? it looks great on your truck.
td
Post by td »
Freddie wrote:those trucks all looks great, but please can someone confirm how much they remove from the front coils when they do a half flip on the rear holder please. Another question i have is what is the best tire combination and the best offset for the rear tires. thanks.
You cant cut more than 1 whole round off the front coils without running into real negative camber issues and 1 coil would match the half flip well
marz68
Post by marz68 »
guhfluh wrote:I can finally post here now!
[ Image ]
[ Image ]
Damn! that's a nice truck right there!!
guhfluh
Post by guhfluh »
[ Image ]
[ Image ]
Thanks Marz! You need to make some bolt on parts for me to be able to bag it ;)
cole71
Post by cole71 »
Finally able to post in this thread! Here's mine with DJM dream beams with a coil cut, and a full hanger flip with the helper spring removed. I still need to get the right size tires.
moon.dog62
Post by moon.dog62 »
Cole 71 your truck looks killer man. Such a good stance.
cole71
Post by cole71 »
moon.dog62 wrote:Cole 71 your truck looks killer man. Such a good stance.
Thanks moon!
Hotrodphil
Post by Hotrodphil »
pincheweddo wrote:[ Image ]
That's a nice set up. How much did you lower your truck?
HotRodder Glenn
Post by HotRodder Glenn »
cole71 wrote:Finally able to post in this thread! Here's mine with DJM dream beams with a coil cut, and a full hanger flip with the helper spring removed. I still need to get the right size tires.
Mind if I ask what size tires you have now? And what size tires you are getting? Why don't the ones on there now fit correctly?
Trying to learn what I need before I drop my truck.
Thanks,
Glenn
Grease Monkey
Post by Grease Monkey »
Dream Beams with a coil cut on old springs in front. Hanger flip and longer shackles with overload spring removed and 6* shim added in rear.
It's got a little rake, and a little more negative camber than I really want. Probably add some new front springs to even the rake and take out the negative camber eventually, but I'll run her like this for now.
HotRodder Glenn
Grease Monkey wrote:Dream Beams with a coil cut on old springs in front. Hanger flip and longer shackles with overload spring removed and 6* shim added in rear.
I wonder if a half a coil would help that? The truck sits nice, that is what I am looking for in the spring. How close is the rear to the snubber or frame? Any issues with bottoming out at all?
Grease Monkey
HotRodder Glenn wrote:I wonder if a half a coil would help that? The truck sits nice, that is what I am looking for in the spring. How close is the rear to the snubber or frame? Any issues with bottoming out at all?
I'm actually pretty good with it now. I let a friend drive it down the street, and the camber looks fine as he drives by. Seems that how much you want to trim depends on age, mileage, and conditions the springs were used in over the years. Mine were already sagging a bit before I cut one round off.
I trimmed some off of all my bumpstops, probably wasn't necessary but gave me extra clearance for some big potholes. I haven't bottomed it out yet, and don't think it will. Unless I haul something pretty heavy in the bed...... which I don't plan on, my truck is retired! :lol:
