Fliping the front hanger
- wt4speed#2
I have already flipped the hanger . I had some questions as to the amount I gained . These pictures show various points on the frame beore and after. At the end of the frame rail the diffence shown between the blue tape is 6 1/4"
At the rear spring hanger in front of the cross memeber
Before
Cross memeber at front spring hanger between the cab and cross member
Before
After
Rear hanger before
After
Before
Before
After
Rear hanger before
After
- F100builder
re: Fliping the front hanger
Cool. Thanks for the info! It looks like about 3-3/8" at the front hanger and 5-1/2" at the rear hanger. So, if the axle tube is roughly halfway between the spring eyes, it would be about 4-3/8 to 4-1/2 inches at the center of the wheel opening yes? Do you have pictures of the truck with the bed back on it yet? I'm not 100% sure yet but I'll probably be doing the full flip. Man, you did a lot of work just for some numbers but thanks again!!!
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
- wt4speed#2
This is all I have the 1st one is original pic of the truck while it was DD.(edit0You cant tell from the 1st pic ,and one of the reasons I took that shot, the bed is full of fully assembled 302 . The second is the bed just sitting and may not be down as far as it should.
kinda gives "me" an idea of where it will end up.
The pic of the weld is what i was shooting for.
Didn't take me long to do it,
- wt4speed#2
- F100builder
It looks to me like it will fit with a styleside too due to the bed's crossmember thickness but the full flip looks to be the maximum for the hanger only flip. It looks like it's exactly what I want. Best of all, no $$$ except for some new grade 8 bolts.
Patrick
- basketcase0302
Tony,
Good job man!
Good job man!
ok, so stop me if i'm wrong, but by flipping the front hanger, didn't the wheel move forward in the wheel opening??
note: 'bout time you do something to that poor neglected truck
- wt4speed#2
Re: re: Fliping the front hanger
If you are judging by the picture with the weld I dont think we had the bed all the way forward were it belonged. Juding by the factory holes and where it's now bolted, if it moved front or back it went back and not enough to matter. When you come by I'll show you what I'm talking about and you be the judge.fitzwell wrote:ok, so stop me if i'm wrong, but by flipping the front hanger, didn't the wheel move forward in the wheel opening??
- zoomer
Re: Fliping the front hanger
Maybe I missed it, but what if any degree of shims did you put in to make up the difference with the pinion angle?
1971 Ford F100 Sport
302 3 on the tree
Revelation 12:11
And they overcame him by the blood of the Lamb, and by the word of their testimony; and they loved not their lives unto the death.
By this I am a Monster to the Monster!!
- BobbyFord
Because of different rate springs and the different amount of arc or sag, the degree of angle shims necessary to bring pinion angle into spec. will vary from vehicle to vehicle. You simply have to measure pinion angle after hanger mod and go from there. 4-5 degrees of pinion angle will work.zoomer wrote:Maybe I missed it, but what if any degree of shims did you put in to make up the difference with the pinion angle?
- zoomer
Thanks Bobby!BobbyFord wrote:Because of different rate springs and the different amount of arc or sag, the degree of angle shims necessary to bring pinion angle into spec. will vary from vehicle to vehicle. You simply have to measure pinion angle after hanger mod and go from there. 4-5 degrees of pinion angle will work.zoomer wrote:Maybe I missed it, but what if any degree of shims did you put in to make up the difference with the pinion angle?
302 3 on the tree
Revelation 12:11
any more pictures of this modification. did you have to c-notch it.
