front sway bar option
- tybob81
did any 67-72 f100 2wd's come with a front sway bar? On the 73-79 what models do i need to look for that would have that option? Any one certain year than another?
re: front sway bar option
Some of our trucks did come with front swaybars, but probably not what you're used to seeing. They fit between the radius arms:
The '73-up trucks did come with the convential swaybar style. Look for them on some F250s and almost all F350s. Here's the setup I got from an F350:
Here's a picture of a van setup, but it shows you how the bracket is mounted:
....and here's an exploded-view schematic of the swaybar setup:
http://www.fordification.com/board/73-7 ... ematic.gif
- rjewkes
I thought the I beams where a form of Anti sway device. Wouldn't new busshing once every Year or two keep it from swaying or are we looking for the side to side sway cuased by cornering?
fuelly.com
fuelly.com
The I-beams are the axles, and have no anti-sway function. As you mentioned, when you take a fast corner and scrape the door handles or load up a large cab-over camper and start hitting some sidewinds, that's when you need a good anti-sway bar.
- xxxtina63
Well, the pics explain why you sometimes can't use headers & sway bars.
My FORDification Photo Album
Right....the style which go between the radius arms is the style referred to in the header catalogs when they say "...will not fit with factory swaybar". The front-mounted style will work just fine with headers though.
- tybob81
so the 73-up f250 and f350 2wd sway bar will work on a f100? Thats awsome because i have a 78 f250 rust bucket thats about to go to the crusher at the farm with sway bars will the rear sway bar work on my 68's 9'' the 78 is some type of dana.
- tybob81
Keith you are the MAN!! I would have never thought the f250's would have worked
The FRONT swaybar from the later F250s will work. However, the later 2WD trucks have a rear frame section that is 4" wider, so their swaybars won't fit....although the factory highboys up through '77 still have our narrower framerail spacing, so those swaybars should work just fine.
- tybob81
cool, I'll keep a look out to try and find a hi boy to get the rear sway bar. thanks for the useful info
- turbocharged400sbc
damn, i wish the 79 F350 2wd i stole the front susp from had the swaybar...damn
good info though thanks!
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
Addco also has a front swaybar for our truck. I ordered one for around $140 and it bolted on in the front very easily. Very good mod for the cost. Really made a difference. I think it was addco #113
I have never seen the one that goes between the radius arms. I wonder how well they worked?
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
well If you want a front sway bar try looking under a 74 up Camper Special almost every one of these trucks had one. I mounted one in my truck and It didn't do much at all. and I have seen two stiles one mount in front (of I beams) that works ok and one mounted in back (on the radios arms) thats junk and not recommended.
I found the back axle one is more affective then you are takeing that hard corner with that over hight load.
WHAT ?
- 1971ford
Re: re: front sway bar option
im going to be running headers, so i guess i need "the front-mounted style". what exactly is the front-mounted style?FORDification wrote:Right....the style which go between the radius arms is the style referred to in the header catalogs when they say "...will not fit with factory swaybar". The front-mounted style will work just fine with headers though.
where does it mount to?
ill have to give my dad good info on what i need when i send him in the junkyard looking for one.
-Ryan
- 390Nut
At the bottom of the post Keith has up above (the one with all the pictures) is a link to the diagram for the sway bar. Click that and print it out.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
