3511 flange
3511 flange
I'm trying to track down a 3511 Flange, steering column tube (C5DZ-3511-B) for a 1969 F100 Ranger w/a C6 ........ any ideas ?? from anyone ?? It seems that that particular part shows up on several different Fords between early 60's and mid to late 70's. The challenge has become locating the little bugger. Again I'm back to any ideas?? from anyone ?? appreciate your time on this.
- Scalawag
Re: 3511 flange
Any luck finding this part? Or were you able to find a substitute? I'm in the same boat.D+D wrote:I'm trying to track down a 3511 Flange, steering column tube (C5DZ-3511-B) for a 1969 F100 Ranger w/a C6 ........ any ideas ?? from anyone ?? It seems that that particular part shows up on several different Fords between early 60's and mid to late 70's. The challenge has become locating the little bugger. Again I'm back to any ideas?? from anyone ?? appreciate your time on this.
Quinn
Re: 3511 flange
He's talking about the "tube flange". The collar that goes between the steering wheel and the shift collar that holds your turn signal switch.
Re: 3511 flange
He needs to post in parts wanted and say which trans he has would also help.
Re: 3511 flange
Good point, Craig. They would different depending on which column. The one I posted is for an auto column.
- Scalawag
Re: 3511 flange
Yeah I needed the auto column flange as well. Instead of just finding the part, I ended up buying an entire steering assembly from another member. Problem solved.
Quinn
