Ford C^ Overdrive
Timd
Ford C^ Overdrive
Postby Timd » Thu Sep 21, 2017 9:37 am
Hi all,
I have a C6 tranny that has overdrive, it doesn't have anything special attached to it, my question is, I have been reading that Ford never made a C6 with overdrive, if I have a C6 tranny that jumps into overdrive when I floor it then where did it come from?
Thanks
1969 Ford F100 Custom Cab
302
1972hiboy
Re: Ford C^ Overdrive
Postby 1972hiboy » Thu Sep 21, 2017 10:42 am
Gear vendor?
got and pics?
Rich
1972 f250 ranger XLT Camper Special 390
Dont eat yellow snow.....
colnago
Postby colnago » Thu Sep 21, 2017 4:46 pm
Are you sure that's overdrive? The C6 has a shift-down lever; when you floor it, the C6 downshifts to second so you have some oomph for passing.
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
1972hiboy
Postby 1972hiboy » Thu Sep 21, 2017 5:27 pm
colnago wrote:Are you sure that's overdrive? The C6 has a shift-down lever; when you floor it, the C6 downshifts to second so you have some oomph for passing.
oooh that makes more sense. For a C6, overdrive would mean a fourth gear. But down shifting into passing gear is not the same as overdrive. I recall being confused with that sort of terminology when I was younger.
Rich
Timd
Postby Timd » Thu Sep 21, 2017 7:56 pm
Ah I bet the shift down is it, that makes sense.
Thank you
302
Return to “Drivetrain”
Who is online
