Pinion seal
massillon preacher
Pinion seal
Postby massillon preacher » Thu Sep 07, 2017 4:34 pm
Pinion seal was leaking out the sides, changed the pinion seal now its leaking out the flange nut area, is the flange nut not down far enough? I have rear end out of truck and after I changed pinion seal I put cardboard under rear end with the flange part hanging down towards card board, no leak at all after 24 hours but it's been about 72 or more when I look today and I can see it coming from the nut area?
eggman918
Re: Pinion seal
Postby eggman918 » Thu Sep 07, 2017 7:41 pm
Did you use silicone under the washer?
Steve
massillon preacher
Re: Pinion seal
Postby massillon preacher » Thu Sep 07, 2017 8:17 pm
No and not sure there was a washer there
eggman918
Re: Pinion seal
Postby eggman918 » Fri Sep 08, 2017 10:00 am
Remove the nut and washer clean with brake kleen and reassemble with silicone and blue LocTite :2cents:
Steve
Re: Pinion seal
Postby sargentrs » Sat Sep 09, 2017 5:40 am
massillon preacher wrote:No and not sure there was a washer there
Should have been? http://www.fordification.com/tech/image ... ential.jpg
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding. Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
1964 Ford Fairlane 500. 289/Cruise-O-Matic, A/C, P/S.
Return to “Drivetrain”
Who is online
