So This is Why It Goes "Clunk!"
colnago
Postby colnago » Sun Sep 03, 2017 8:02 pm
I think the photo says it all. The good ends were connected to the slip joint on my C6, the munched ends were connected to the connecting shaft. Good thing I needed to get a new connecting shaft anyway!
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
Jacksdad
Re: So This is Why It Goes "Clunk!"
Postby Jacksdad » Sun Sep 03, 2017 9:21 pm
Okay, I thought my UJs were bad when I found I'd lost the needle bearings in one, but you have me beat by a mile. And them some.
Yes, you definitely found the source of at least one clunk. But it's a bump. There's always going to be another somewhere :wink:
Postby sargentrs » Mon Sep 04, 2017 6:06 am
Ouch! Close call on that one. :eek:
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding. Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
1964 Ford Fairlane 500. 289/Cruise-O-Matic, A/C, P/S.
Mancar1
Postby Mancar1 » Mon Sep 04, 2017 2:54 pm
Ok the photo pushed me to action.
Been going to replace the u joints in the 68 CS for a while now. Think I will getter done. :lol: :thup:
Thanks Joseph, and Keep on Trucking...........John.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Lee
Postby Lee » Fri Sep 08, 2017 11:56 am
Hi,
By chance are the failed ends,... the ends that are secured with the U-bolts?
Reason I ask is because I have had a similar failure with fairly new U-joints. The reason was I was over tightening the U-bolts, crushing the needle bearing caps.
Take care,
Lee
colnago
Postby colnago » Sun Sep 10, 2017 3:01 pm
Lee wrote:By chance are the failed ends,... the ends that are secured with the U-bolts?
In my case, I had a slip yoke coming out from the C6 transmission, and it didn’t use U-bolts. Neither did the coupling shaft. The C6 had a long tailshaft, and the coupling shaft was only 2" in diameter, so I'm wondering if the whole thing came out of a car. Also, the U-joint is the smaller 1310, not the 1330 that should be in a 3/4-ton truck. I figure that I probably had less than a month before it completely dissolved on me.
Good to know about overtightening the U-bolts. I'm putting in a different C6, and it does use the U-bolts. I can definitely see myself crunching down with a wrench, to make sure it's not loose.
Manny
Postby Manny » Sat Sep 30, 2017 8:38 pm
Wow just saw those man talking about paper thin!!! :eek:
Dapper Dan
67' F-250 CS high boy
360 4 bbl
4 speed
d44-d60 4.10 gears
Dr Farnsworth
Postby Dr Farnsworth » Thu Oct 19, 2017 8:40 pm
Get a tire up in the air and rotate the driveshaft back and forth by hand while you have the truck in gear or park (motor off and on a jack stand). Look and and feel for any movement on each of the U-joints. If there is any movement you need to replace the joint.
Replace if the U-joint won't take any grease. It can be a sign of rust or contamination in the U-joint.
Unfortunately, this does not work 100% of the time, so use any random excuse as a reason to replace a U-joint.
I had a front one fail on me years ago, it destroyed the ENTIRE drive-train, engine, all the way to the rear axle.
1969 F100 ranger (for sale)
1978 F250 Ranger 4X4
1966 F100
Ohiotinkerer
Postby Ohiotinkerer » Fri Oct 20, 2017 5:05 pm
Dr Farnsworth wrote:Get a tire up in the air and rotate the driveshaft back and forth by hand while you have the truck in gear or park (motor off and on a jack stand). Look and and feel for any movement on each of the U-joints. If there is any movement you need to replace the joint.
After losing a rear one between Cheyenne and Rawlins Wyoming years ago when I would go to visit family in Idaho I ALWAYS replace them on any vehicle I get that has them no matter they look good and/or take grease......there is nothing between those 2 cities and did manage to limp it (at 40 mph on I-80) into Rawlins where it cost me $140 to have both u joints replaced...... After that experience I look at it as cheap insurance and piece of mind......... :D
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
Return to “Drivetrain”
Who is online
