Shift rod from Column to transmission
I need some help with disconnecting the shift rod rod that goes to my column to my automatic trans. The trucks a 67 f100 with a c6 auto and a 390 swaped in. How do i remove that rod from the column I need to remove the trans to replace the flexplate. Any help with this would be great guys
Re: Shift rod from Column to transmission
If it has the plastic bushing you just have to pry the rod out of it.
Spray a little lube on it.
sometimes they come out hard.
Yeah it has the plastic bushing on it does it matter what gear it's in also? And thank you for replying too.
No any gear , just make sure it doesn't roll while you're under there.
