Adjusting clutch on np435
lennyp
Post by lennyp »
I'm having a problem with my clutch on a 1970 ford f250 4x4. The clutch engages with the slightest movement of the clutch pedal. I have about 1 to 1 1/2" of free travel in the pedal. Having a problem downshifting from 4th to third. How can I solve this problem? Just had the transmission out to replace the clutch fork pivot clip. Clutch looked fine. Any help will be greatly appreciated.
Lee
Re: Adjusting clutch on np435
Post by Lee »
Well,... this is the way I do it....
Take the inspection cover off from the bottom of the flywheel. Look up in there at the Throw out bearing. I then adjust the clutch rod linkage so that the Throw out bearing is close but not touching the pressure plate springs. Say 1/8 to 1/4 inch gap.
If the bearing is touching the pressure plate it means it will be spinning all of the time and will prematurely fail.
hope this helps,
Lee
Busboy
Post by Busboy »
Ive seen pressure plates drag due to worn levers. Even though your free play is right it will still drag. Are you able to shift it into first at idle without grinding? That should tell you whether or not the clutch is disengaging completely.
1967 F-100 4x4 custom cab.
