c6 tranny vacuum modulator
Timd
Post by Timd »
So I pulled my vacuum modulator and almost all my fluid drained out the hole, I don't believe this is normal? there was also some fluid in my modulator, is this normal?
1969 Ford F100 Custom Cab
302
windhamdw
Re: c6 tranny vacuum modulator
Post by windhamdw »
i pulled the vacuum line off mine a few weeks ago and i had no fluid come, if that helps.
Timd
Post by Timd »
Did you have the truck lifted at an angle?
302
windhamdw
Post by windhamdw »
no, it was setting on all four wheels.
Post by colnago »
I had to pull my modulator off last fall. The tranny slowly dripped fluid out, but I doubt if it lost 1/4 cup over an hour. It was parked in my driveway, so at a slight incline. I don't remember if there was any fluid in the modulator itself.
On edit, there was also a plunger of some sort inside the tranny, behind the modulator. While I had the modulator off, this plunger tried to "creep" out of the hole. Could you be missing this plunger, and that's why it drained the tranny of all its fluid?
Busboy
Post by Busboy »
If you have fluid leaking out of the modulator vacuum nipple then it is time for a new modulator.
1967 F-100 4x4 custom cab.
