4 speed interchange
M-100
4 speed interchange
Post by M-100 »
Will a 4 speed that was on an fe work on a small block by simply changing the bell house ? And will the 3 speed bell work on the 4 speed?
eggman918
Re: 4 speed interchange
Post by eggman918 »
IIRC threr is a difference in input shaft length between the small block and the big block trans's
Steve
Canonman67
Post by Canonman67 »
I believe it will work if the depth of the bell housing is the same. Make sure you check that the pilot bearing is the correct size.
