1967 F100 - 4 speed Toploader
EasyE
Post by EasyE »
New guy here. Over the weekend I bought a 67 f100 stepside with a late model roller 302 in it. It currently has an FMX auto in it, but I have a 4 speed toploader that I'd like to put in there.
I was able to find a 164 tooth flywheel with a 50 oz imbalance to match the engine and fit the bellhousing, but I have some other questions.
First, I'm wondering if I can use the mechanical Z-bar to hook the pedal up to the clutch fork? I'm really struggling with this. I've been looking around and I'm finding several versions of the Z-bar, and I don't know if the one that was stock with the 3 speed (it originally had a 3 speed) will be in the correct location. It looks like I'll be out about $150ish for the Z-bar and all the little brackets and crap that go with it, plus another $50ish for a throwout bearing. Alternatively I could just buy a hydraulic setup with internal slave cylinder for $600ish and be totally done with it (which at this point is looking like a nice option). Is there a performance/durability advantage to one or the other; hydraulic vs. mechanical? If the Z-bar will work, which toploader clutch fork do I need?
Second, I've searched on this forum a little and elsewhere and it looks like the 4 speed toploader swap has been done before, but here and there I'm seeing people mention that the shifter is positioned too far toward the seat. Is that correct? Is there anything to be done about that? Do you just go with it? I have some bucket seats I could put in if it looks like the bench seat will be in the way, but just wanted to get some more info on this.
Thanks all.
EasyE
Re: 1967 F100 - 4 speed Toploader
Post by EasyE »
Just a follow up, I went out and looked under my truck and there aren't any attachments that I saw for the clutch Z-bar. I am confused, because it already has a 3rd pedal and the pedal linkage inside the cab is all there. I'd expect there to be the brackets on the frame for the Z-bar.
Also I measured where the shifter handle will end up, and it's about 3" from the front of the bench seat. Also I think I'm going to put bucket seats in anyhow, so should be fine.
eggman918
Post by eggman918 »
Steve
EasyE
Post by EasyE »
Thanks eggman. I saw that image and that's how I know I'm missing stuff. PN 7507 in the bottom left corner is missing, nor are there any holes drilled for it. Why wouldn't there be any holes if the truck was a manual before?
Also, if that mechanical linkage is what I need, will it match up to where the toploader's clutch fork sits?
Btw, what's the 918 in your username for? Not by chance an area code is it?
eggman918
Post by eggman918 »
918 is law enforcement code for erratic behavior like 5150 is for crazy :wink:
Steve
EasyE
Post by EasyE »
Gotcha.
So I'm also considering the crown vic swap, so I may scrap this idea anyway. I dunno, we'll see.
Gonna go do some reading on that.
eggman918
Post by eggman918 »
It's been many moons but IIRC the toploader's shifter is all external and controlled with rods,so you should be able to fab rods in whatever configuration you need to put shifter body where you want :2cents:
Steve
