3 Speed Column Shift Pin
RavenBlack67
Post by RavenBlack67 »
The shift pin broke that holds my shift lever in the column. That was no fun. I am looking at parts to replace and the pin that was inside my 1967 F100 3 speed column shift looked like two caps with a spring like this:
http://cgfordparts.com/ufolder/cgcat.ph ... 01A-7221-K
One of the caps was in pieces and the spring was stretched and bent when I got it out. That part is supposed to be for much older F100's 53-55. The part recommended by some parts websites that I've just found are showing a rolled solid piece of metal like this:
http://cgfordparts.com/ufolder/cgcat.ph ... t=357479-S
Which is the correct part and how is it supposed to stay in place? Just tap it in? Thanks.
Re: 3 Speed Column Shift Pin
The second one is the correct part http://cgfordparts.com/ufolder/cgcat.ph ... t=357479-S It just taps into place.
RavenBlack67
Thank you! That's what I'll get.
