Speedometer Conversion
idahiboy
Post by idahiboy »
Has anyone done electronic speedometer conversion?
I have 1968 f250 manual transmission (np 235 and Dana T case). Old speedometer cable was manual....
I am trying to upgrade to New Vintage guages with electronic speedometer... Not sure how to get adapter into T case....
Anyone converted to electronic speedometer for these trucks? What did you use for sender?
This is a photo of the sender that came with the speedometer
http://newvintageusallc.mybigcommerce.c ... er-sender/
Thanks for any insight!
1968 F250 FE 390
idahiboy
Re: Speedometer Conversion
Post by idahiboy »
All of the adapters are a big nut vs the smaller stock cable screw/twist on.
Advice? Pictures of anyone who has done this. The hall effect adapters all hit the nut/pto plate.... If I could just extend things out a few inches then things would fit.
It's a Dana 24
1968 F250 FE 390
cstoyer
Post by cstoyer »
The adapter you are showing would work in the NP 205 T-Case as its a push in style with a screw to retain it compared to the threaded Dana/Spicer 24 type. I have both a 24 and 205 with cables and when I install the 205 I'll use the adapter you have pictured to mate to the original 24 speedo cable.
Dakota Digital has a kit for updating to modern gauges with a Retro Look if you are looking for a one stop shop.
CStoyer
68 F250 4x4
