Trying to identify rear cone
Rossd
Post by Rossd »
Hello All;
I have been put to what I am getting the sense is a fools errand. I have been trying desperatly to find a rear cone to a ford transmission as seen in the attached photo. This part appears to be unfindable by Google and I am at my wits end. Does anyone have any idea how to better identify and subsequently locate a replacement rear cone matching this one?
Any help is appreciated.
Ross
wheeble
Re: Trying to identify rear cone
Post by wheeble »
Post a picture of the pan.
1971 F100, Balanced and blueprinted 390. Rebuilt AOD transmission and drive line. Repainted back to factory colors (seafoam lower, boxwood upper).
Rossd
Post by Rossd »
wheeble wrote:Post a picture of the pan.
Wheeble,
Thank you for looking. No pan actually. It connects to a Quaife tranny.
Ross
Canonman67
Post by Canonman67 »
What is this in? What motor? Can you please post pictures of the entire unit? Thanks
wheeble
Post by wheeble »
I googled quaife sequential gearbox. Selected images and found lots of links and info. However, I have zero knowledge of the boxes except they are expensive.
mmerlinn
Post by mmerlinn »
I know this thread is old, however based on what I read and see, this transmission appears to be a T-9 box.
Compare with the pictures here (http://www.mgexp.com/phorum/read.php?1,1570799).
Google for T-9 boxes and see if that is what has the correct housing.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
Rossd
Post by Rossd »
mmerlinn wrote:I know this thread is old, however based on what I read and see, this transmission appears to be a T-9 box.
Thank you. I'll check it out and see if it gets me closer. I really appreciate the help.
R
