Intake and Carburetor
Jzbochat
Post by Jzbochat »
I have a 1972 f100 with a 390 in it. The motor still has original intake and carburetor. I was wondering if I would have any problems changing the carb out for a Edelbrock 1405 4 barrel and an Edelbrock 2105 intake?
Manny
Re: Intake and Carburetor
Post by Manny »
Nope shouldn't be a problem. Its a little more involved on the FE engines as you have to removed the rocker shafts and pushrods to get the intake off. In this make certain you keep the narrow rocker shaft bolt at the oil hole is the only thing that can bite you. I would recommend a holley over the edelbrock. Just my :2cents:
Jzbochat
Post by Jzbochat »
Thank you for the advice I will look into it.
tnlprt
Post by tnlprt »
If you decide to change the intake on your FE engine search on the page for the tips and tricks..
The FE intake swap has some minor quirks
