1974 Ford F250 / 360 CID 5.9L / Vacuum Hose Diagram
SonofBigfoot
Post by SonofBigfoot »
Hi - I'm a newbie on Fortification...
I need diagrams / photos / that show proper routing of vacuum lines from Motorcraft 2100 / 2bbl to the various terminals, the distributor vacuum advance, the TSS/ PVS, the EGR, and various devices, the SDV valve, check valve etc.
I found some information / electric diagrams / vacuum lines / routing / and even most specifications, which I posted to Facebook page.
I also included much information on Holley 4160 carburetors, tuning, and performance tips.
Any additional information would be most appreciated.
Thanks.
Trapper ED
:wel:
https://www.facebook.com/Bigfoot.Traps2017?__nodl
bigfootsnares@gmail.com
Re: 1974 Ford F250 / 360 CID 5.9L / Vacuum Hose Diagram
:wel:
Ed,
You might have better luck finding that vacuum diagram on the "sister" site for dentsides: :wink:
http://www.fordification.net/
colnago
Post by colnago »
There's also tech sections, not in the discussion forums, if you go directly to www.fordification.com or www.fordification.net. You can get to the forums from here, but you can also get to the tech sections, that have wiring schematics, mechanical break-downs (with potential part numbers), assembly diagrams, etc. While we all enjoy the discussions, there's more to these sites than the forums.
SonofBigfoot
:wel:
I already read those and check the site for this information before I posted my request @ GO figure? Anyways, a 1974 2 X 4 f250 is not a 71 or 72, and a 360cid is not a 302 or a 351...or a 4x4 either... Different beasts, so I asked... But I was hoping for help... Seriously... Not be dazzled by statistics or baffled by AN on everything else. Also the website seems spotty with many pages coming up 404, or blank. There is a general Danger in Blogs in that a person can post wrong information and then this misinformation creates more issues than good.... Something to consider beyond braggadocio.... Just saying... Trapper ED
