Exhaust manifold gaskets.
Busboy
Post by Busboy »
What's the difference between the exhaust heat shields and the exhaust manifold gaskets on the 390's? Were they equipped with both? All the supplier list both items.
1967 F-100 4x4 custom cab.
eggman918
Re: Exhaust manifold gaskets.
Post by eggman918 »
I always had good luck with just the heat shields coated on both sides with copper anti-seize ....But only if the heads and manifolds mating surfaces were surfaced to be sure they are flat :2cents:
Steve
Ditto, if flat they don't 'need' gaskets. If they aren't, gaskets won't help for long.
eggman918
Post by eggman918 »
:yt: ...exactly
Steve
HIO Silver
Post by HIO Silver »
If not flat, consider Remflex gaskets.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
colnago
Post by colnago »
How "flat" is "flat"? I had the heads reconditioned a few years ago, in prep for a rebuild. I doubt if he replaned the exhaust surface (he concentrated on new valves and hardened seat inserts). But I don't recall them being rusty, either. They are probably average, for a 50-year-old engine, which means they're probably good but with minor pitting. Is this okay, or am I going to need gaskets, or am I going to need resurfacing? I know; without pics, this is somewhat subjective. I'm just looking for a SWAG.
HIO Silver
If the exhaust flange only has minor pits, some high temp RTV is doable but ya gotta let it fully cure so it doesn't get blown out.
68 Mustang
65 Mustang
eggman918
Post by eggman918 »
Steve
