Engine runs ruff
sledman3064
Engine runs ruff
Post by sledman3064 »
I have a 1970 f100 1/2 ton 4wd w/ a 360. The issue I am having is that my truck runs like it is choked when I give it full throttle and acts fine when I let off I think its a carb issue but I could be wrong please help thanks
sledman3064
Re: Engine runs ruff
I also have a 2bbl on it the carb was rebuilt about a year and a half ago if that helps
bluef250
Post by bluef250 »
check the carb float and needle valve assembly.
jf100
Post by jf100 »
Do you have manual choke? If so check to make sure it has smooth action. I just got through working on mine. I will know when I leave for work in the morning. It does seem to be running a lot smoother at idle. Hope this helps
