How to remove belt?
Timd
How to remove belt?
Post by Timd »
What is the easiest way to remove the belts from an old 302?
Thanks
1969 Ford F100 Custom Cab
302
Re: How to remove belt?
Fan belts? Cut 'em off. They're cheap and probably need replacing anyway. Take the old one's with you when you get new one's just in case the auto parts guy's an idiot. Otherwise, depending on your option equipment, just loosen the mounting bolts and adjustment bracket bolts. Everything is adjustable so loosening the bolts will allow you to take the tension off and just slide them off the pulleys. If you have a radiator fan shroud, you'll have to work them around the fan to get them out but no need to take anything off.
TNIceWolf
Post by TNIceWolf »
I always prefer the method Randy prescribed of loosening the bolts. You are going to have to loosen them anyway to reinstall the belts. And a lot of parts jockeys these days dont have a clue how properly size a cut belt with a belt gauge. You also want to use some common sense. Some of the accesories arent just going to drop off the belt when you loosen them. They may take some persuasive force to move in the desired direction. Dont go to hammering and prying until you triple check that all the bolts are loose. If you are reinstalling some prying to get correct belt tension will be required in some cases.....dont go all gorilla on that. On reinstall be sure to lock down the adjustment bolts first and the pivot bolts last.
Presently in the stable
1969 Ford F-350 DRW
Busboy
Post by Busboy »
Wow.
1967 F-100 4x4 custom cab.
Timd
Post by Timd »
Thank you all very much, I just bought a 69 Ford f100 and haven't wrenched for a very long time and I was pretty sure I could just loosen adjust then remove but wanted to make sure.
302
colnago
Post by colnago »
TNIceWolf wrote:On reinstall be sure to lock down the adjustment bolts first and the pivot bolts last.
Why? I wouldn't have thought the order made any difference, but then I've not changed a belt ... yet.
HIO Silver
Post by HIO Silver »
I rotate old belts as spares cuz ya never know...
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Ren
Post by Ren »
Youtube is a good source to get a clue when you don't know what yer doing.
Don't cut the old belts. Keep them as spares.
TNIceWolf
Post by TNIceWolf »
Thats just my personal preference and something I was taught decades ago both in high school auto shop and In the Army when I was learning to be an M1 tank mechanic. The idea is if you are adjusting say a V belt type driven alternator by yourself you need two different tools one in each hand.
A pry bar to apply tension and a wrench to seat a bolt. You can do it either way. But the adjusting bolt is usually easier to get to. I myself prefer to set the tension and have both hands free to deal with the pivot bolt which is often harder to get to and requires somewhat more torque applied. A socket...ratchet and often an extension are much easier to handle with two hands.
1969 Ford F-350 DRW
