What are these?
71PA_Highboy
What are these?
Post by 71PA_Highboy »
In the pic, what is the cable referenced by arrow #1?
What is the decal referenced by arow #2?
(it is not the tune-up specs, that is on the other side)
Original photos here:
http://www.fordification.com/70explorer_358miles.htm
Thanks!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
Norton
Re: What are these?
Post by Norton »
The cable looks to be your heater control. The decal could be an emissions decal.
1971 Highboy
'76 460 transplant, NP 435, D60 4.10 rear, D44 4.09 front, PS, PB, factory A/C
71PA_Highboy
Re: What are these?
Heater cable is just to the left of the arrow.
Emissions decal is on the other side. See all the original photos for more detail.
Got Ford?
1 Lincoln Mark VIII
gregamorton
Re: What are these?
Post by gregamorton »
I am not sure but will take a wild guess. On some of the special ordered trucks they had the pull for overdrive, maybe that. And the decal could it be on the wrong side?
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
71PA_Highboy
Re: What are these?
You can see a different (and correct) decal on the other side in the other pics.
In the interior pics and in the description there is no mention of an overdrive. That said, I have never seen an overdrive so I will not comment on whether you are correct or not... I don't have a clue.. ;)
Got Ford?
1 Lincoln Mark VIII
Norton
Re: What are these?
Post by Norton »
I have a cable coming through the exact same spot on the firewall of my 71 highboy but instead of crossing over to the passenger side, it goes straight down below the master cylinder -- er, uh, brake booster -- and travels across the top of the driver side frame rail to the back of my transfer case. So, I'm gonna say speedo cable.
Here's an example of an emissions sticker:
I thought you said the tune-up specs were on the driver side valve cover?
1971 Highboy
71PA_Highboy
Re: What are these?
Those are the tune-up specs.... ;)
A rose by any other name...
The one on the passenger side looks to have a Ford script in negative of the one you are showing.
As for the cable, seems odd, but I think you are right as there is no cable coming down on the drivers side...
Got Ford?
1 Lincoln Mark VIII
Norton
Re: What are these?
Post by Norton »
71PA_Highboy wrote:Those are the tune-up specs.... ;)
By golly they are. About all I can see is whats at the top. I tried to blow up the picture of the truck you posted but it's just as blurry blown up as it is to me small.
1971 Highboy
mrollings53
Re: What are these?
Post by mrollings53 »
I would hazard a guess that the cable is the speedo cable. It comes out from behind the instrument cluster and then worms around to the right side of the motor where the cable hooks up at the transmission.
Common Sense is an Uncommon Virtue
ericknight
Re: What are these?
Post by ericknight »
That truck is an automatic so it's not an overdrive cable.
tidybowl
Re: What are these?
Post by tidybowl »
what ever it is, if you cut it you'll find out. :lol: just kidding. I'd trace that sucker even if it means taking loose the clamps and see where it goes. If there's aftermarket A/C it could be controlling the passengers side vent. The decal you're looking at is the output specs for the alternator. You should be able to find it at Dennis Carpenter's. PS that sucker is wayyyyyy too clean. You need to get it dirty :evil:
1970 F-250 Camper Special 390/C-4 auto 289K miles, 1992 Explorer 4x4 229K Miles, 2000F-150 4.2L V6 154K miles
ericknight
Re: What are these?
Mine would be that clean if it only had 358 miles on it. http://www.fordification.com/70explorer_358miles.htm
Racer Z
Re: What are these?
Post by Racer Z »
I see two cables. Not sure which one the arrow points at. One is the water flow control for the heater. The other is the speedometer cable.
