rocker shaft tubes
dlabby
rocker shaft tubes
Postby dlabby » Thu Apr 05, 2012 6:38 pm
i am puttting inlifters and pushrods in a 1970 f100 with a 390 , question is do the rocker tube holes go upor down to oil ? the shafts had 1 up and 1 down when i took apart
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: rocker shaft tubes
Postby 1970 Hi-Boy » Mon Apr 09, 2012 8:03 am
Here's what it says in my 1970 Ford Shop Manual, and I'll type word for word, the section that is in bold print on this subject in the book. - "Be sure the shaft is positioned so that the oil holes are to the bottom. Also the identification notch on the end of the shaft must be downward and toward the front on the right bank, or toward the rear on the left bank."(page 21-06-08 Volume two-Engines) Hope that answers your question.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
blumule
Postby blumule » Mon Apr 09, 2012 2:06 pm
down, down, down.
Return to “Engine”
Users browsing this forum: Ren
