Downshifting issues
- thrush544
Downshifting issues
Hello,
I bought a 69 F-100 with a 302 from Florida, an original Georgia truck. The previous owner rebuilt the engine and did a very nice job. However I am having issues with her downshifting. The slightest incline induced petal push makes her downshift. Usually she'll jump from about 2700/2800 rpm clear to 3800.3900 rpm which is at the very limit of her torque curve and she is just sreaming and going nowhere fast. I cringe just waiting for a rod to go through the side of the block!!! The only adjustment I found on the kickdown rod would be to shorten it one hole. (I just looked at it qickly with my dad one dark evening.) Could it be the wrong rod, or would it kicking in sooner make it better if I shorten the rod. Maybe he rebuilt the engine so it's out of poop by 3500 rpm. Whick would be puzzeling because it doesn'tseem to have an excessive lower end torque either.
I thank you all in advance for any help!
Take Care & God Bless,
Ed
Ed
"Courage is being scared to death, but saddling up anyway." - John Wayne
Proverbs 3: 5-6
Proverbs 3: 5-6
Re: Downshifting issues
follow air vac line from carb or manifold to trans pull the hose off and there is sometimes an allen head adj inside the vac controll if it had been replaced good luck wes
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
- basketcase0302
I know that truck is no slouch! Seen it in action at a couple of our MNG's. There are several tranny adjustments you could try, (I would first start with the kickdown).
Our "little 302's" as some folks on here call them...are not stump pulling low end torque monsters without putting some 4.56 gears into your 9". I'd bet that engine was not built for low end torque, but for mid range like most folks would use to tow with.have an excessive lower end torque either.
yes it could be a modulator adjustment. or it could be the kick down rod or linkage adjustment.
- thrush544
Thanks guys, Is there any bullitens, manuals or books where I can read up on this (of course when I read I )?
Proverbs 3: 5-6
Proverbs 3: 5-6
- basketcase0302
Here's the only TSB that i could find that was even close to your downshifting issue:
http://www.fordification.com/tsb/viewto ... ?f=4&t=318
Maybe someone else with a little more experience with the kickdown rods will pipe in.
- 70_F100
If it's got more than one hole on either end, it's not stock.thrush544 wrote: The only adjustment I found on the kickdown rod would be to shorten it one hole.
The only kickdown adjustment from the factory was at the carburetor, where the linkage attached.
That's not an oil leak That's SWEAT from all that HORSEPOWER!!
I only have one factory 2v here in my shop to look at but I thought there was a screw or bolt at above the kickdown rod arm on the throttle to adjust the kick down? It has been a while since I have looked at one all hooked up though.
I also didn't think the Modulator valve would adjust the kick down RPM. I thought it works in conjunction with the governor to control the shifts of the transmission through one two and three. Probably wrong but at least if I am it might bring forth some conversation on the matter.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- 70_F100
Clint, you're right about the adjustment. One screw on a small lever on the carb, assuming Motorcraft/Autolite 2100.
The modulator and governor also play a small part in the kickdown process. When I had the C6 in my truck, the kickdown linkage was never connected after I installed the 600 Holley. At certain speeds, kickdown would occur (mainly low speeds). By that same token, if I wanted to make SURE it dropped down a gear, I had to do it manually.
Of course, now that I have a T19, the kickdown rod is connected to my left foot and right hand... Much more positive now...
- TX69F100
Without the kickdown linkage installed, the truck should never drop from 3rd to 2nd when you're on the throttle at cruising speeds. Kickdown linkage does not affect the 2/1. As was stated already, you should be able to tweak the amount of pedal required to achieve kickdown by an adjustment screw on the carb. Kickdown achieves the same result as pulling the shifter down into 2nd (it actually operates the same mechanism on the valve body). It will not allow the upshift until you back out of the throttle enough such that the lever is no longer depressed.
