I'm trying to assemble my rocker arm shafts now that I bought new shafts. Does anyone have any tips for putting the pedestals on the new shafts. They are very clean but have a very tight fit. I just don't want to break anything by beating on them.
Any tips out there?
Thanks.
Assembling new rocker arm shafts.
- fordamericana
Re: Assembling new rocker arm shafts.
I watched a guy at the local machine shop use a piece of brass tube, thick wall I assume considering how soft the metal is, to tap the pedistals into place on a set of rocker rails...mdc32073 wrote:I'm trying to assemble my rocker arm shafts now that I bought new shafts. Does anyone have any tips for putting the pedestals on the new shafts. They are very clean but have a very tight fit. I just don't want to break anything by beating on them.
Any tips out there?
Thanks.
You have new rockers too? I was looking at Kanter and they had the shafts for a real good price, but everywhere I have found lately the rockers were like between eight and twelve dollars each...
I likes My FE I does...
No, not new rockers. The old ones. I'm really broke for money right now. But, when I took them apart for inspection the shafts were really worn looking so I couldn't in my right mind not at least replace the shafts.
Thanks for the input...I'll see if I can find something like that. I don't think I have a brass pipe. Maybe my friend has something at his garage.
- fordamericana
The shafts were worn but not the bearing inside the rockers? You are a lucky fellow, I had to buy four separate set of rocker rails from local wrecking yards before I found a non damaged set for my last rebuild. I still wish I could afford those pretty roller rocker set ups I've seen pop up on the market the last couple years, but eight hundred is way out of my budget right now. LOLmdc32073 wrote:No, not new rockers. The old ones. I'm really broke for money right now. But, when I took them apart for inspection the shafts were really worn looking so I couldn't in my right mind not at least replace the shafts.
These don't have any bearings in them. At least there were none when disassembling them. They are from a 360 FE. They are just the stock rocker arms and shafts. The book I'm using as reference (How to Rebuild Big-Block Ford Engines by Steve Christ) didn't mention any bearings for them either.
Sometimes they get a little tight/deformed from bolt torque. Try running a brake cylinder hone through them for just a second with some WD40. Or a piece of sandpaper in a cotter pin chucked in the drill if you're really running on a budget. They should simply slide on with a very modest push press - no hammering needed.
- BobbyFord
Make sure the oiling holes point down before installing the assembly. Excessive shaft wear can indicate an oiling issue. Is this a complete rebuild or are you just replacing the shafts?
I used a 12 Gauge copper cleaning brush from my shotgun cleaning kit....LOL. It did the trick for cleaning the pedestals out good. Then I put the shafts and pedestals in the freezer for a while. Once they were past the end of the shaft they slid on fairly easily.Barry_R wrote:Sometimes they get a little tight/deformed from bolt torque. Try running a brake cylinder hone through them for just a second with some WD40. Or a piece of sandpaper in a cotter pin chucked in the drill if you're really running on a budget. They should simply slide on with a very modest push press - no hammering needed.
The rocker arms went on with no pressure at all. Just the pedestals were a little tough going on.
I'm just replacing the shafts. The other parts looked fine after a good cleaning. The oiling holes are pointing down. I checked a few posts here before going forward with the install. I wouldn't have know that otherwise. Thanks for stating that though. Before I read the post about that I thought they would go up top. That would have sucked!BobbyFord wrote:Make sure the oiling holes point down before installing the assembly. Excessive shaft wear can indicate an oiling issue. Is this a complete rebuild or are you just replacing the shafts?
Thanks for all the input guys. I have them all together now and just have to put them on the heads.
