My 460 Build
- BobbyFord
My 460 Build
I decided to use my other heads for my build. These are C9VE heads (same as D0VE). I've had these on the shelf for a few years, I had them done for another engine but never used them. Just got some new springs and rocker arms.
Intake and exhaust ports were max-ported.
Intake port:
Exhaust port:
2.08"/1.66" valves were removed and heads were machined to accept 2.19" stainless steel intake and 1.76" exhaust valves:
These are the Comp Hi-Tech stainless steel roller rockers (ain't they purty). I got these because I'm paranoid about component failure (these have a lifetime warranty against rocker arm breakage). I've seen aluminum rocker arms break before.
The short block is assembled, I just have to put the heads on and figure out the rocker arm geometry (pushrod length). I also have to overhaul the trans that's on my garage floor next week.
It has been a lot of fun (and money ) gathering all of the bits and pieces and I can't wait to hear this thing run. I still have to get a carb and a bunch of little misc. stuff.
Intake port:
Exhaust port:
- dantheman71
Re: My 460 Build
No replacement for displacement!! That thing is gonna fly
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
2002 Ford F-150
- OldRedFord
Re: My 460 Build
How did you keep the heads so nice during that time?
I am almost at the same point. As soon as the block comes back from the machine shop it is time to check rocker geometry also.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- BobbyFord
Re: My 460 Build
The heads were oiled, wrapped plastic and boxed in a dry garage.OldRedFord wrote:How did you keep the heads so nice during that time?
Just follow the extended post on 460ford.com about the rocker arm geometry: http://www.460ford.com/forum/showthread.php?t=141907
- sideoilerfe
Re: My 460 Build
Cool! Keep us posted.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- basketcase0302
Re: My 460 Build
You won't be able to keep tires on the back of that short bed!
Re: My 460 Build
Thats some nice port work. Looks good
- BobbyFord
Re: My 460 Build
Cylinder heads were done by Scotty J at RHP. http://reincarnation-automotive.com/brandon.k wrote:Thats some nice port work. Looks good
- hotrodfeguy
- BobbyFord
Re: My 460 Build
Custom grind, solid, flat tappet cam .553/.575, 231/241 @.050 on 108LSAhotrodfeguy wrote:Cam?
- convincor
Re: My 460 Build
And I've seen stainless break- http://www.ffcobra.com/forums/showthread.php?t=187922BobbyFord wrote:img]
stainless or not there "cast". Aluminum's are forged and also are lighter.
"Still Plays With Trucks"
- BobbyFord
Re: My 460 Build
Not too sure what problems that guy had with his valvetrain setup but I will not have the same problems with mine. I've seen WAY more broken aluminum rockers than I have seen broken steel rockers.convincor wrote:And I've seen stainless break- http://www.ffcobra.com/forums/showthread.php?t=187922BobbyFord wrote:img]
Forged aluminum is good but what they're forged out of is more important.
- convincor
Re: My 460 Build
just pointing out they can still break. And sure you may see more broken aluminum there's probably 1 set of stainless to 100 sets of aluminum. The only cast stainless out there are the Comp's.
Re: My 460 Build
What year block and what pistons are you using? I sure would like a set of heads like that but can't afford to do any engine work on mine. I had a nice set of stock Dove's once and had to sell them for bills.
The 460 in my 71 F100 is pretty stock low compression engine with just a small cam, headers and 4v carb but it'll move my long bed pretty good. Can't imagine what your engine is going to be like in a short bed but should be LOTS of fun
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- hotrodfeguy
Re: My 460 Build
Beautiful cam and combo so far. Keep us posted
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
