Moderators: DuckRyder, FORDification
DuckRyder wrote:Assuming that the machine work and clearances were good to start with there should be minimal machining of checking or clearances.
DuckRyder wrote:Plastigauge is cheap, it basically looks like a string, you place a bit of in between the surfaces (like the rod bearing and crank) tighten the cap and then remove the cap, you then compare the now mashed string to a scale on the wrapper to determine the clearance. You'd need to do that on each bearing. It is absolutely imperative that the lifters be kept in order and go back on the same cam lobe...
DuckRyder wrote:You'd need a ring compressor and a valve spring compressor to really do it right, you can probably "rent" these locally...
DuckRyder wrote:If the main and rod bearings have metal in them then you are going to want to replace the cam bearings too, that means a trip to a machine shop and its highly recommended it be one familiar with FE's.
robroy wrote:Robert, in your estimation, about how much does a stripped down FE block weigh? Can a guy pick it up by himself? I'm just wondering how easy it is to move around.
DuckRyder wrote:150 - 200 lbs Maybe, it is a one man and a hoist or a two man job...
You can use the hoist to slide it off the engine stand if you have to, then there is usually someone at the machine shop that will help you unload it, at least around here there is... In my experience the stand is usually about the right height that you can man handle it in and out of a truck
Ranchero50 wrote:The sludge on the outside is the dirty stuff. Should be clean inside (like the oil that poured out first). At this point I wouldn't bother with the filter anymore. What's scary to ponder is all that crap came through the pump and was getting flung around inside the motor while the crank was chewing on the windage tray.
Ranchero50 wrote:That's the teardown, scary eh?
Ranchero50 wrote:Wait until you put it together, we'll have 10-20 pages of threads on that.
Ranchero50 wrote:Personal suggestion is pull it apart yourself and clean it up, but get someone you trust to put it back together for you.
Ranchero50 wrote:Get price quptes both ways though, some shops don't like basket cases.
DuckRyder wrote:That is a pretty impressive oil filter, I think the bypass probably opened and that is how the top end got metal up there, it could not have splashed/slung up there, so either it was pumped up there or there is some thing up there rubbing.
DuckRyder wrote:I've been giving this some thought, while I'm sure you can accomplish it, there are some nuances that are going to be hard to explain and there is really no substitute for an experienced hand, I do think you would be better off if you could at least get someone with some experience to come assist. I don't know if that is possible or not.
DuckRyder wrote:BTW, after you take the rod cap off, slide a piece of fuel hose over the bolts so they can't scratch the crank.
DuckRyder wrote:The Haynes should give you an idea of what is involved, but definitely get the Steve Christ book for the actual build.
DuckRyder wrote:Reminds me of Dads story about the Clymer manual for the Bultaco (or it could have been a husky or a maico) any way hes removing the clutch basket from the crank the book says "remove the bolt securing the clutch basket to the crankshaft", he tries everything nothing will loosen it, ends up breaking it off. Turns the page and it has "note: this is a left hand thread".
DuckRyder wrote:Or the time I was trying to look up the freon charge for a Volvo in a Chilton book. The entire A/C section is "Consult a qualified Air Conditioning technician", remind me why I bought this book?
DuckRyder wrote:Yeah, I wouldn't worry about doing anything else with the filter, it looks like it saved you from it being much worse, but it does appear that some got past it.
70_F100 wrote:All of the advice I've read here is good, no doubt.![]()
I still maintain that the bearings should be checked before buttoning it up.
If there is some embedded metal, a set of bearings is VERY inexpensive insurance against ruining a crankshaft (or worse).
Again, the small amount of time and trouble to check them is, in my opinion, well worth the peace of mind that it will provide.![]()
Just my
What's the worst that could happen? And after how many miles? (Realistically)
What's the best that could happen?
What is your personal, best guess as to what would actually happen?
Users browsing this forum: danno and 3 guests
