NEW TECH ARTICLE: Fuel Tank Sending Unit Tech
General website and forum announcements
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
I just posted another another new tech article, this one a basic tutorial on how to troubleshoot a non-functioning fuel gauge. I've outlined how to test a sending unit and have included pictures. The new tutorial is available from the Technical Papers page, or you can CLICK HERE to view the new page. Any input is welcome, including anything that needs to be added or corrected.
cobraF100
re: NEW TECH ARTICLE: Fuel Tank Sending Unit Tech
Post by cobraF100 »
Nice...........Thanks
Chris
Never Forget Our Soldiers
heep70
Post by heep70 »
Boy, I could had used that about a year ago. Great job. :thup:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
FORDification
Site & Forum Admin
Site & Forum Admin
Thanks guys....and just for the record, I found a couple very minor errors in the page just now and have corrected them. :D
FORDification
Site & Forum Admin
Site & Forum Admin
I added a picture of the instrument cluster voltage regulator to this page for easier identification.
bluef250
Post by bluef250 »
Great article. Have this to add. My truck’s fuel gauge was working somewhat. When the tank was filled, the needle went to the 3/4 mark sometimes and sometimes did not move at all. :x When the gauge was working, I removed the wire to the main tank and held the wire to ground, the gauge went to full. Bad sending unit! Problem solved, well . . . ! :hmm: The information did not add up since this problem had been going on for sometime and sometimes the gauge did not work at all after switching between the main and auxiliary tanks. Also, bad sending units in both tanks? After consulting several web sites on fuel gauge issues, two mechanics, and wiring diagram, I decided to look at the main/axillary tank switch. After removing switch, I tested it for continuity - none. After disassembling the toggle switch, cleaning, and carefully putting the thing back together (lost the springs 3 times) - well lubricated with dielectric grease, I tested the switch again. Now, it had continuity. After reinstalling the switch in the truck, and I got readings on both fuel tanks.:D
FORDification
Site & Forum Admin
Site & Forum Admin
Thanks for the tip bluef250. I just added your suggestion to the page. :thup:
oldhalftons
Post by oldhalftons »
nice work on that page , thats real helpful :clap: but I do have one question.
if you have a stock sending unit and power it from the dash voltage regulator can you use an aftermarket gauge like a Autometer NV series ?
they are lised for Ford applications with a 73-10 ohms sending unit.
