67' longbed build
Charlie67f100
Re: 67' longbed build
Post by Charlie67f100 »
Well the alternator light works and bright light on the dash but all the rest and the dome still don't what else is left
pedro69ford
Post by pedro69ford »
I would check your grounds good..the dome is black with a blue stripe comes thru and down the driver side pillar and bullet plugs into another lead behind the dash.I would check those for voltage.the dash lights are light blue with red stripe I would check those aswell for voltage and ground..let us know what you find
Charlie67f100
OK I will but what about the flasher cylinder is that box the flashers
pedro69ford
The emergency flashers have a plug in the glove box , with a toggle switch.some have a block that plugs in to keep current flowing thru the circuit..can you post pics of which you have..
Charlie67f100
I would but I'm not sure how too
Charlie67f100
I've got the toggle switch in the dash but there's a but the before that you know how it usually has a cylinder flasher unit there's a box instead I think it might be a hd flasher unit if you can tell me how to post pics I will put some up for you.
Charlie67f100
Look on my gallery I've got it uploaded for you now
pedro69ford
sorry i had a hard time logging in from my mobil,your emergency flasher should be round just like turn signal flasher,
pedro69ford
its a possibility that is a flasher hard to really know unless you cross that part number.what color wires are present for that box in the pic
pedro69ford
i believe they are one red, one red with white stripe and one white with red stripe.,for the emergency flasher.
Charlie67f100
That's the colors on the wires but there is also a blue one tied in with the white and red stripe
pedro69ford
is it factory or did someone splice that in?
Charlie67f100
It look factory I'm gonna try replacing the flasher and see what happens with that.
Charlie67f100
Hey but could you tell me which fuel line goes from the pump to the carb on the fuel pump there is one going to the tank from the pump and one going from the pump to the carb I'm not getting gas to the carb bowl I can put gas in the bowl and prime it and she fires up and runs til it use the fuel
pedro69ford
well it should be pretty straight forward there,did you check for fuel from the tank to the carb? i would disconnect the line at the carb and turn it over a few times and see if you have any pressure at all.could be a weak pump.let me know im here for awhile .
