Inline fuel pump
Shubin2
Inline fuel pump
Post by Shubin2 »
Swapping out my blown 352fe for a 06 5.3LM7. Which inline fuel pump would some of you recommend?
Madman
Re: Inline fuel pump
Post by Madman »
May be better to place this question in a more appropriate forum, I'm sure someone will be able to address your question.
2017 Ford Raptor
1975 Ford Bronco
hackster
Post by hackster »
I agree that it needs to be in the right forum.
Since its here though....are you running the stock fuel tank? You will need to figure out how to get a supply and return line into the stock tank if you are.
I need to know more before I make a recommendation.
If you are doing the mustang tank in the back of the truck, I highly recommend the Phantom in tank setup. It just flat works, fits great and is quiet.
I am running dual Bosch 044's on my ls swapped truck. They are pretty noisy but deliver a firehose of fuel up front.
Single Bosch would be plenty. How are you regulating the pressure to the rails?
Sean
