Grumps 1972 long to short project
GrumpsGarage
Post by GrumpsGarage »
New project started. 1972 F100, has a swapped in 460. Plans are swapping in a Crown Victoria front suspension and a Explorer rear end with 3.73 gears, limited slip and Disk brakes. I'll try to keep this thread updated as the build goes along. Advise and comments are always welcome and encouraged.
Grumps Garage
1972 F100, Long bed to short bed, Crown Vic front and Explorer rear, frame up resto-mod
Daily driver
2012 F150 FX4 SuperCrew
yarko
Re: Grumps 1972 long to short project
Post by yarko »
Right on! Can't wait to see some updates!
GrumpsGarage
Let the tear down begin. The body is pretty straight, but there is some rust that will need to be taken care of.Image
Image 1976 460 was swapped in a couple of years ago, still running good. Previous owner said the engine has approx. 40,xxx miles on it, just needs some performance goodies. Just want a nice cruiser, not looking for a dragster or tow rig.
Grumps Garage
Daily driver
GrumpsGarage
Full tear down in progress. Running some parts to the storage unit to get them out of the way.
[img Image
Image ][/img]
Grumps Garage
Daily driver
GrumpsGarage
Looks like the drivers side floor board will have to be replaced or patched.Image
Grumps Garage
Daily driver
GrumpsGarage
460 pulled out, thinking I'll just clean it up, maybe new intake and cImage
Imagearb combo. I'll look into some headers for it also.
Grumps Garage
Daily driver
GrumpsGarage
Pulled the bed off, man some of those bolts just didn't want to come out. Image
Image I made this cart for my truck bed. I think it will help when it comes time to make a short bed out of it.
Grumps Garage
Daily driver
GrumpsGarage
Made a trip to Vegas, spent some money, and actually brought something back with me for a change.Image
Imagee.
Grumps Garage
Daily driver
GrumpsGarage
Long bed to short bed, starts with cutting the frame. The point of no return! the sawzall made short work of the frame.Image
Image Welded in some fish plate on the inside of the frame and more than likely I will box this section of frame in. Might be over kill. The wire wheel and grinder/sander will get a work out cleaning this frame all up. I will follow it up with some POR-15 and some top coat.
Grumps Garage
Daily driver
GrumpsGarage
Time to get the rear axle out, the flame wrench makes short work of the old rusted u-bolts.
Grumps Garage
Daily driver
GrumpsGarage
I have an Explorer 8.8 with 3.73 limited slip gears, with disk brakes, just waiting to get installed.
Image Hopefully I can find a way to use the sway bay and the traction bars.
Grumps Garage
Daily driver
GrumpsGarage
Time to start cutting apart the front suspension, so I can make room for the Crown Vic suspension.
Grumps Garage
Daily driver
Monkey-1
Post by Monkey-1 »
Excellent start! Subscribed...
-Monkey-1
Studmonkeyracing.com
studmonkey@bellsouth.net
Wilfred of Ivanhoe
Post by Wilfred of Ivanhoe »
Very cool project! Looks like you got a hold of a very clean truck too!
1969 F100 LWB Parts truck
GrumpsGarage
Started ripping and tearing the front suspension out, about the time I realized I didn't mark the center line of the hubs, It was too late.
[imgImage][/img]
Grumps Garage
Daily driver
