Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
SeapineF37
Re: Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Post by SeapineF37 »
Yeah wiring is the pits. Tedious and after a bunch of work its not even photo worthy...
But gots to be done and good on ya for workin through it. I'm still trying to get through mine :cry:
Looking forward to the next photo worth update!
Madman
Post by Madman »
SeapineF37 wrote:Yeah wiring is the pits. Tedious and after a bunch of work its not even photo worthy...
I will say that the Painless Wiring Kit, although spendy, is well worth it when it comes to simplicity and not having to re-invent the routing of wires again. It could be a lot worse!
2017 Ford Raptor
1975 Ford Bronco
magic bus
Post by magic bus »
Looking good indeed, :woohoo:
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
Madman
Post by Madman »
My wife helped me this weekend, and we got the full floor vinyl installed on the truck. Much easier with an extra set of hands!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Then today I got the gas tank back in.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Got the Passenger side inner fender painted, under coated, and weird ass seal installed yesterday.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Pulling and routing the wires on the passenger side.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
And installed the radiator support.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
I'll post this in the interior section as well, but I found a great substitute headliner material. I got this piece of Vinyl at home depot for $22. It is 4x8 and white, but I believe it can be painted. It was advertised as shelf bases, but it is perfect for a headliner!
I used the trim to rough outline the shape and size, cut it big to allow trimming to size in place.
I basically screwed it up in the overhead in the center portion and worked outward, screwing it down and trimming it in place.
Final product I believe looks good!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
I then got my auxiliary fuel tank installed in the rear of the frame, installed the fuel transfer solenoid valve, and fuel lines. A flip of the toggle switch will transfer suction from the main tank in the cab to this 32 gallon monster!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Installed the inner fender and routed the wires from the painless wiring kit, and installed the solenoid and voltage regulator, as well as the heater hoses. I am awaiting the Champion aluminum radiator, they had to modify the mounting brackets for my truck. FYI Universal Champion Radiators that they swear fit all 67-72 Ford trucks only fit 2wd's. The bracket has to be rotated from front to back to fit 4x4's.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
And here I dropped some coin on a big upgrade, the Edelbrock E street fuel injection system....spendy but sweet!
2017 Ford Raptor
1975 Ford Bronco
Lone Ranger
Post by Lone Ranger »
I just read your entire thread... You my friend are doing great work! No stone unturned here. I'm a huge highboy fan and you are making them sweeter. Keep it up! Can't wait to see it put together around that motor.
Kyle
Madman
Post by Madman »
Lone Ranger wrote:I just read your entire thread... You my friend are doing great work! No stone unturned here. I'm a huge highboy fan and you are making them sweeter. Keep it up! Can't wait to see it put together around that motor.
Thank you! I hope that some of you breathing life back into these trucks can take away something from my posts and put it to good use on yours! :thup:
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
2017 Ford Raptor
1975 Ford Bronco
