1972 F-250 Highboy Restoration
Madman
Re: 1972 F-250 Highboy Restoration
Post by Madman »
Looks like you are doing a very nice job, much attention to detail!
2017 Ford Raptor
1975 Ford Bronco
SkyBlue72
Post by SkyBlue72 »
I would seriously NEVER take it outside when it's done...if it were mine. That is a top shelf restoration you got going on.
sopikp1
Post by sopikp1 »
Gents, thanks for the posts, you're all too kind. SkyBlue - it's kinda funny isn't it? When complete this beast will have tons of hp, new parts everywhere, and be soundly set up for all sorts of crazy off-road adventure. But I'm not sure it will ever see rain!!
Thanks again,
Kevyn
Kevyn
1972 F-250 4x4, 390, Dana 44, 24, 60
sopikp1
Post by sopikp1 »
Nothing exciting, but here are a few more recent pics. Starting to make brake lines and getting ready to begin building the Dana 44. Should have NP 435 and Dana transfer case pics tomorrow - after rebuild. Thanks for all the posts!
Kevyn
sopikp1
Post by sopikp1 »
Just picked up my Dana 24 and NP435 from the gear shop in Council Bluffs, IA. They look pretty good! :thup:
Kevyn
Manny
Post by Manny »
Looking very very sharp no doubt a top notch restoration going on here. Got some money tied up in it but for sure something to be proud of when it is done. Pat yourself on the back Kevyn your are doing yourself proud here!!! :2cents:
sopikp1
Post by sopikp1 »
Got a little work done today, finished back axles and put the rear tires on. I re-used my old e-brake cables, touched up with a little paint. We bolted up the Dana 44, and put the new bearings in the knuckles - this takes a little patience and trial & error to get the bearing load correct. With any luck, we'll finish the front axle this week, and start on the engine and transmission soon.
Interesting thing, I have four identical sized Ford 16.5" rims, but two would not fit over the rear axle housing??? I've never seen that, I assume they are off of something else? Thankfully, they fit the front no problem. Any ideas?
It's been a while since this frame has been on tires - I forgot how high these Highboys sit, even with stock tires...
Kevyn
sopikp1
Post by sopikp1 »
Few more pics..
Kevyn
sopikp1
Post by sopikp1 »
And some more.
Kevyn
Manny
Post by Manny »
Okay i speak i think for several of these guys here (maybe maybe not). You have proven your point that you are building one of the nicest highboys ever seen and you can now stop making us feel bad............. :rant:
Nah not really i am enjoying this very much if there was such thing as ford playboy this would have to be it right here..... :pop:
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Post by 1970 Hi-Boy »
That's a fine job you're doing there by the looks of it. Just thought I might mention to you that you may consider fabricating a brace from the bottom of the Dana 24 transfer up to the crossmember in front of the 24 running up at an angle. It takes any jiggle out of it and makes it study like a transmission mounted transfer, especially when you dump the clutch on that FE powered beast. Should be a lot easier with the body off. Keep up the good work. :clap:
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
sopikp1
Post by sopikp1 »
Been a while since I've posted, it's good to be back. I've spent entirely too much time tracking down brake parts lately....We finished most of the brakes and dropped in the 390 and transmission today. We also bolted on the transfer case. We mocked up the power steering pump and alternator, fan, etc.
For the new steering gear box, we've cut out part of the radiator support and radiator. The 1.5"x6" piece we cut out included one of the radiator screws, so we actually moved the mount and welded it up so there is still two screws on each side. This whole process took a while, but the power steering will be worth it. i'll get some pics posted.
A few weeks back we put the 390 on the dynometer at Willard Auto Machine here in Omaha, I've never done this, good time! The expert broke it in and fine tuned everything for an hour, including carb jets and timing. After several runs, the final numbers were 371hp and 444 lbs. of torque. The engine was built for torque, and it delivered at all rpm's.
We hope to start bending lines soon, and installing the gas tank.
Thanks for the idea 70 Hi-Boy.
Kevyn
sopikp1
Post by sopikp1 »
A few more pic...
Kevyn
fencepost0_1
Post by fencepost0_1 »
Loving the build, can't never post to many pics.
sopikp1
Post by sopikp1 »
Some progress today, got the Warn hubs on and the driveshafts. Started the brakelines, and promptly screwed up 3! :x
Hope to get the lines done, the fuel tank mounted, and then this chassis is off to the body shop for sheet metal.
Jays fought hard against NC, just not enough firepower tonight!
Kevyn
