Chronicles of Project Hank
tubolove
Re: Chronicles of Project Hank
Post by tubolove »
Using airbags up front so ride height is infinitely adjustable. I too had considered raising the oem beams up to about 2* neg camber (about 2"). Then bend the beams back to 0.5* neg camber. Seems like a lot to bend. And who the heck even has one of those I beam bending tools anymore anyway?
Theses are all very plausable suggestions. Thank you.
Alstoyz
Post by Alstoyz »
DUH!!! I completely forgot you were running air bags. As far as bending the beams, I've been told that big rig alignment shops have a hydraulic press to bend the beams.?.? :?
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
tubolove
Post by tubolove »
Ill find out tomorrow. My friend owns Deland truck center. Maybe he has some insight.
Alstoyz
Post by Alstoyz »
:thup:
1972 F-100 SWB 4X4
Heirloom
Post by Heirloom »
Heating and hydraulic pressing is the way it's done.
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
tubolove
Post by tubolove »
So after looking at my straight f250 Ibeams, and googling 67 f350 I beams I noticed they are both completely straight. While contemplating my options this morning staring at my front end I noticed that The 1978 model I-beams I am using have an upward bend on them near I-beam bushing and then go straight from there. Since the I beam bushing part juts up it thought maybe I can just relocate the I beam mounting hole upwards and bring the whole beam vertically upwards. After some careful measuring I decided it could go up 1 & 3/4" and still leave sufficient clearance for travel up and down. Turns out that was the perfect amount. Top of tire is now exactly even with the fender at a ride height maintaining 0.5 degrees of negative camber! By golly I think I've got it!!!
Alstoyz
Post by Alstoyz »
KOOL BEANZ!!! :thup:
1972 F-100 SWB 4X4
tubolove
Post by tubolove »
Here's a comparison;
tubolove
Post by tubolove »
Front 3/4 comparison;
Alstoyz
Post by Alstoyz »
:bow: by George I believe you've done it!!!
1972 F-100 SWB 4X4
Alstoyz
Post by Alstoyz »
Hey Tom... Howz ol Hank doing??? I'm chomping at the bit to see sum updates... :lol:
:fr:
1972 F-100 SWB 4X4
tubolove
Post by tubolove »
Well here's the dealio. Bought stock I beams and relocated the holes upwards. Problem is the ps ibeam is bent but the ds ibeam is straight. It hits the engine mount crossmember on up travel. I could notch the crossmember but that was only problem number one. The drop I beams are 1/2" frigging wider than the oem beams. This means NONE of the brackets I fabricated fit. On the oem beams my lower airbag brackets hit the frame. The sway bar brackets won't fit in the old shock mounts as designed. What a mess. So in leu of refabbing all those parts I am again using the drop beams but dropping them. I removed the ibeam pivot brackets today and am building drop brackets to rocate the I beams down 1-1/2". Going weds to buy the steel. 2-1/2 x 1-1/2 x 1/4 is hard to come by on Sunday.
Alstoyz
Post by Alstoyz »
I understand bout the lack of supplies on a Sunday... :lol: it soundz like you've got it figured out.?. Good luck with it... I really can't wait 2 see the progress. I REALLY DIG DUALLY'S!!! :thup: specially bump (6) wheelers... :D
:fr:
1972 F-100 SWB 4X4
tubolove
Post by tubolove »
I'd be lying if I said I wasn't a bit frustrated.... :hw: :hw:
Alstoyz
Post by Alstoyz »
Feel your pain brother... I've got a few of those myself... :cry:
1972 F-100 SWB 4X4
