Chassis Swap (1972 onto a 2002 Chassis)
70 ranger
Re: Chassis Swap (1972 onto a 2002 Chassis)
Post by 70 ranger »
Man that looks great! I love a clean stock bump, but the upgrades you get from a body swap are the ultimate. I saw you made a post about mating the old column to the newer box. What I did was cut of the rag joint, then i cut the last 2" of off the newer column and welded it to the older column. I atached the newer knuckle to the new piece on the column. The shaft coming out of the newer box had a slip joint already. So I just cut it down to size and it has been working great. I will try to post a pic.
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
FoPAR
Post by FoPAR »
Thank's for your input Tyler, your very right bout the way the others look. I like them, but not for this truck. I will be ordering the the upper right one in the next day or so....
That's good to hear cause it sounds similiar to what I have been thinking of. I'm just not at that point yet, I still have to pull the one out of the 2002 and see how it matches up. It also has a slip joint and a few knuckles. So it should work out close to what you did..... :pray: ..... :lol:
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
rjewkes
Post by rjewkes »
I'm considering adding a knuckle, u joint connection on my next truck. no more rag joints.
fuelly.com
FoPAR
Post by FoPAR »
I've sold some more parts and haven't spent any more money, so time to look at the budget again.
Project Budget
Bought 77 Lincoln Mark V       -$300.00
sold wheels & tires                       $40.00
sold rear end                      $200.00
scrap run                                        $67.00
scrap run                                        $87.00
scrap run                                      $108.00
Total From Lincoln                 $202.00
Bought 2002 F-150
-$500.00
sold engine                        $200.00
sold trany                           $200.00
sold tailgate (damaged)        $25.00
recycled catalytic converters  $115.00
mis. Interior parts               $45.00
grill                                        $40.00
rear bumper (damaged)        $15.00
front bumper                        $50.00
Door (drivers side) complete   $150.00
Hood                                      $100.00
Drivers side Fender               $75.00
passenger side Fender         $75.00
Rear Slider window              $100.00
mis. Interior parts                   $50.00
Total From F-150       $740.00
Sold from shop/home
sold air compressor         $175.00
sold wheels & tires         $125.00
scrap run from shop         $125.00
Edelbrock 360/390 intake      $150.00
Total From Shop         $575.00
Total $1517.00
welding supplys                        -$60.00
cut off wheels & blades        -$40.00
1/8" plate 12" x 8'                   -$60.00
4" x 20'   "C" channel               -$98.00
460 engine mounts                 -$60.00
pneumatic hole punch             -$40.00
shop supplies                     -$95.00
Total Parts / Supplies       $1064.00 left over
And I still have these parts up for sale:
For Sale / 2002 F-150
Door (passenger) complete        $200.00
Rear door (drivers side)         $150.00
Rear door (passenger side)        $150.00
For Sale / 1972 Ford
Wheels & Tires        $250.00
Edelbrock 600 carb        $175.00
$1064.00 positive. So the project is paying me?.... :hmm: .....sure looks that way... :D well until I need parts, paint, ect, ect..... :cry:
FoPAR
Post by FoPAR »
Back to work on the front end today. The flat part that's tucked under the front bumper was damage on both ends, so I pounded them back into shape. I also got the frame parts close to lined up but my front bumper is not at all straight so it's making it near to impossible to line up. So it looks like I will need to order a new bumper before I will be able to finish this part of the build.
Very strange on this 2002 frame, not sure why but the drivers side frame rail is larger than the passenger side. as you can see in the next pic's I had to notch, tuck, and overlap the driver side but the passenger side is overlapped by the old frame. :hmm:
Joshpow
Post by Joshpow »
Lookin good. Mine next!! U up yo getting me a deal like that on a truck and buildimg mine!?
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
FoPAR
Post by FoPAR »
lol Sure thing Josh, just as soon as you move to Washington... :D
Joshpow
Post by Joshpow »
Yeah!! Your ol truck is moving along nicely. Itll be cool when youre finished!
Josh
71 F-100 Custom SWB
02 F-250 Stroke
resurrected
Post by resurrected »
Things are looking good with your project keep up the good work
1971 short bed ranger Frankenstein (restoration and customization in progress)
FoPAR
Post by FoPAR »
Well I got a little more done today, I figured now was as good a time as any to fix the nice dent the truck had when I bought it.
Also going to use panels from a 67 to fix it so the bed will have a more smooth look to it. I picked these corner post up from a junk yard for $10 ea.
Cut out my patch panel and then cut out the damaged panel on the truck.
Clamped in the new patch and then started tacking it in.
So after a ton of spot welds it is done.
Now I get to start the drivers side :roll:
Swegner99
Post by Swegner99 »
Bandwidth exceeded... :cry: No pics for me today
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
FoPAR
Post by FoPAR »
should be fixed now.....I can't view the pic's at work so not sure...
Swegner99
Post by Swegner99 »
Its fixed, you do awesome body work. I wish I had that gift, luckily im blessed with good grinding skills..... :thup:
I like the looks of the earlier beds too, without the reflectors.
1999 F150 Ext Cab
fbomb100
Post by fbomb100 »
some added reflectors below the tail lights on the panels from a 67 you got.lol
FoPAR
Post by FoPAR »
Thanks, body work is what I like so I pay attention to any one who will show me how to do it. Still have a lot to learn..............
