'68 F250 Crew Cab 4x4 Short Box - Cummins!
averagef250
Re: '68 F250 Crew Cab 4x4 Short Box
Post by averagef250 »
Looks good, but cup plugs need installed so the sidewalls are fully inside the plug bore. Cup plugs are tapered, if they're not in all the way they can easily come back out.
averagef250 wrote:Looks good, but cup plugs need installed so the sidewalls are fully inside the plug bore. Cup plugs are tapered, if they're not in all the way they can easily come back out.
Good eye and very true, especially of the brass ones... :eek:
At least it shold come apart quicker the second time around. :cry:
Jamie
hivewax
Post by hivewax »
I'm sure the brass plugs take all of the sidewall of the the holes. Why do they have to be flush with the block? Brass shrinks/expands?
Loren Pittack - EngineeRunner, Corp.
'97 Dodge 2500 - 12V Cummins, NV4500, hydro-boost, DANA 80 rear (power-train donor)
'68 F250 4x4 Crew Cab Short Box - work horse parts/car hauler - http://fordification.com/forum/viewtopi ... 22&t=60632
'66 Mustang FASTBACK GT - modified - http://engineerunner.com/vintage-ford.html
The edge of the plug not being in the hole will allow it to expand and contract at a different rate vs. the iron block. It'll work it's way out over time. You may get lucky but it's easier to just drive them in 1/16-1/8" in the bore.
Jamie
hivewax
Post by hivewax »
I got the freeze plugs flush with the block... getting them 1/8" to 1/16" inside the bore would need the engine out. Right now, I just bought 4 BFG All-Terrain 235/85R16 at Discount Tire with free shipping and the big "Super Cooling" 24x26" Spectre radiator 3-row CU480 at APW for $335 - http://frugalmechanic.com/auto-part/spe ... ra&t=CU480
AutoZone and Summit Racing had the radiator for less, but didn't have them in stock and could not get them from the manufacturer. Amazon had them for less by $20-30, but I had to wait 3-5 weeks.
At the moment, I'm installing a 90's Ford 3G 130A alternator and a 90's Ford 2-speed electric fan from a U-Pick yard. I have an extra electric fan if anyone needs it. :thup:
hivewax
Post by hivewax »
Currently still installing the $30 3G 130A alternator. Rainy days and other issues popping up.
Got the TEFBA filter all the way from AUSSIE land.
And, the radiator. It had some slight damage to the fins. The box it was shipped in was over-sized and had been damaged... kind of pissed me off. Packaging was terrible... came straight from SPECTRE. Need to test it to see if it leaks.
hivewax
Post by hivewax »
Here's my 3G wiring.
I think the big wire that the yellow arrow is pointing at needs to go to the positive side of the battery or starter solenoid.
And, it looks like I need to temporarily move the battery inside the cab.
killakobra
Post by killakobra »
what year and model did you pull the alt from?
1967 f100 stepside 300ci I6
1972 longbed trailer
hivewax
Post by hivewax »
I don't know the exact year, but was from a 90's Ford Taurus.
Manny
Post by Manny »
WOW :eek: Them were some nasty freeze plugs. Glad you got them out.....
hivewax
Post by hivewax »
Starter/ignition switch is not working after I did the 3G swap... link - http://www.fordification.com/forum/view ... =8&t=62271
hivewax
Post by hivewax »
Finally got the 3G alternator operational. Just installed today the big radiator and TEFBA coolant filter... need to get some all stainless hose clamps to finish the top hose. Both bottom corners of the radiator bracket had to be notched.
Up next is get the rear brake lights and the front headlights to work!
hivewax
Post by hivewax »
Replaced the original rusted out fuse block with a Bussmann mini-fuse block - http://www.fordification.com/forum/view ... =8&t=62478 ... got the instrument panel and heater control lights to work. Wipers worked when I got the truck. Cigar lighter gets juice, but the coil doesn't heat up. Right turn signal light on instrument panel works, but doesn't blink.
Emergency flashers, turn signals, brake lights, headlights still don't work. Time to study the wiring diagrams.
hivewax
Post by hivewax »
Can't wait to get to the body/frame work. I'm very tempted to go custom. :D
Video example - http://youtu.be/SETrxqCGDsk - check out the Willy Jeep.
1972hiboy
Post by 1972hiboy »
:pop: :pop:
Rich
Dont eat yellow snow.....
