67 Short Bed Build (10/23) Paint Pic
1967AceStroker
Post by 1967AceStroker »
Well, its finally come time to start working on my '67. One last look of the "original" before the transformation.
And here is the rust free donor cab/front end. From '71 F250 Camper Special.
Also going in will be a 351 Cleveland dynoed at 460bhp, followed by a C6.
I plan on many other upgrades, I can post the installations as I do them. And am going to try and frequently update so everyone can see whats happening with my project, but you know how that goes. I also know how much you guys like the pictures, so I will do my best to make sure there are pics with updates.
*1st post edited many times for title update only.*
Last edited by 1967AceStroker on Wed Oct 24, 2012 12:09 am, edited 19 times in total.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
iamthewreckingcrew
Re: '67 Short Wide Build
Post by iamthewreckingcrew »
Keep it comin' :)
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
Joshpow
Post by Joshpow »
Looking forward to more progress.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Skifu
Post by Skifu »
I like what your doing,but theres no way that motor has that much HP,with stock heads,especially at the rear wheels,correct me if Im wrong.
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
rjewkes
Post by rjewkes »
The rockers look to be upgraded perhaps rollers?
fuelly.com
1967AceStroker
Skifu wrote:I like what your doing,but theres no way that motor has that much HP,with stock heads,especially at the rear wheels,correct me if Im wrong.
Thanks. That motor does makes 460hp, at the flywheel. It has stock 4v heads. My dad is the one who had it built years ago, and he has the dyno sheets and he said he would look for them. When he finds them I can take a picture of one of the dyno sheets and post it up.
rjewkes wrote:The rockers look to be upgraded perhaps rollers?
Yep, them sure are roller rockers.
1967AceStroker
Re: '67 Short Wide Build (Update10/24)
Well today I did some disassembly on the truck. I removed the old front end. And I have the cab stripped of everything that I'm not keeping, and all the way ready to take off. I am going to have to wait till tomorow to switch the cabs, gotta wait for the reinforcements to help lift.
papabug71
Post by papabug71 »
4V Clevelands are BAAAD. I only have the 2V version :(
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
brandon.k
Post by brandon.k »
Those 4v's do make good power. I had one in my pickup before i sold it, but it was gone when i bought it back. :lol: My buddy kept the motor when he sold me my ride back. He went back through it with all the high dollar stuff and if i remember right it was some over 500 horse. He put it in his 66 Fairlane with 411's and a 4 speed. That thing was crazy.
hazelnut
Post by hazelnut »
I think 351C is one of fords better motors,its a shame that they only had a 4 year run.i had the 4bbl verson and ive got to say that was one badaaz little motor,good luck with you truck :thup: What size gears you going to be runnin? and please dont run without a drive shaft loop on your truck :2cents:
1967AceStroker
hazelnut wrote:I think 351C is one of fords better motors,its a shame that they only had a 4 year run.i had the 4bbl verson and ive got to say that was one badaaz little motor,good luck with you truck :thup: What size gears you going to be runnin? and please dont run without a drive shaft loop on your truck :2cents:
For now, I am going to run with the factory gears. I'm not sure what ratio the factory gears are though. I plan on putting bigger axles and posi when I find a rear that has posi. And now that you mention it I probably will put a drive shaft loop on.
*edit
My factory gearing is 3.50 - Ford (3300-lb.), acording to the vin#.
Last edited by 1967AceStroker on Sun Oct 25, 2009 8:28 pm, edited 1 time in total.
1967AceStroker
Re: '67 Short Wide Build (Update10/25)
Well, its raining outside, but the truck has a new cab! For now the cab is just sitting up there, and I just set the front wrap on to keep the rain off.
1967AceStroker
Also, this is the paint I want to go with. 2010 Ford Mustang - Kona Blue Metallic
TheMadScientist
Post by TheMadScientist »
NICE!!! Like to see this in person, Hint Hint. You need to come over and see my 72 and my 65 with the 429
2006 F-350 Crew Cab Lariat 4X4 6.0l Diesel Tow Rig
2005 Excursion Limited 4X4 6.0l Tow Rig
1977 F-350 Crew Cab SWB (4x4 soon)
1972 F-350 Crew Cab 4x4 SWB Cummins 12V, NV4500, NP205, HP60,D70B, on 35's
1966 F-250 Crew Cab (4x4 soon)
1965 F-100 SWB 351C 4v
1956 F-100 2wd SWB 429
1972 Bronco Explorer Sport
1969 Mustang Fastback (tubbed and caged, soon to get a 429)
1967 Mustang Fastback 427W, C6
1965 Mustang Fastback 347 FI HO, T5
1967AceStroker
TheMadScientist wrote:NICE!!! Like to see this in person, Hint Hint. You need to come over and see my 72 and my 65 with the 429
Sent you a pm.
