72 F100 project, longbed to short conv, CV swap, 20s
cervantes35
Re: 72 F100 project, longbed to short conv, CV swap, 20s
Post by cervantes35 »
What kind of brake booster and master cylinder did you use. and does it work?
JG F100
Post by JG F100 »
cervantes35 wrote:What kind of brake booster and master cylinder did you use. and does it work?
I used a hydroboost from an astro van and corvette master cylinder, both can be found really cheap. Works great.
72 F100 - SWB conversion w/05 crown vic IFS, 8.8 rear w/disc, 20s, 360FE w/overdrive
Project Page: http://www.fordification.com/forum/view ... 22&t=37897
JG F100
Post by JG F100 »
A went ahead and ordered a new rear bumper and brackets from Dennis Carpenter. Felt it was really missing something...
Before
After
I had to cut a little piece of the leaf spring bracket, maybe I cut too much frame off the ends? DOnt know but it looks good to me.
JG F100
Post by JG F100 »
also took a few more pictures outside
cervantes35
Is the hydro booster from the astro van a direct bolt on. or do you have to modify it?
cervantes35
You have a very nice looking truck
F100builder
Post by F100builder »
Still lovin' your truck... 8) Bumper is looking good!
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
JG F100
Post by JG F100 »
cervantes35 wrote:Is the hydro booster from the astro van a direct bolt on. or do you have to modify it?
Not a direct bolt on, had to modify the firewall and shorten the rod length. There are pictures of it somewhere in this thread
thanks
tylerb43
Post by tylerb43 »
Good Lord, that's an awesome looking truck. The stance is perfect, makes me want to start over! :clap: :clap:
cervantes35
I like the wheels. Could you tell me what the backspace on the wheels are?
XABN82
Post by XABN82 »
tylerb43 wrote:Good Lord, that's an awesome looking truck. The stance is perfect, makes me want to start over! :clap: :clap:
No kidding I love the stance on this truck also. I'd like to achieve the same stance with the DJM dream beams. I hope this is possible. Sweet looking truck, what brand of wheels, size please and tire size also. Thanks
JG F100
Post by JG F100 »
The wheels are 20x10 w/3.75" bs and 20x8.5 w/5.25bs. 275/40s and 245/40s. thanks
JG F100
Post by JG F100 »
Finally got around to notching the frame out back, went to a local steel supply and found a few plates of 3/16" cut to the right size in their scrap pile. paid about $15 bucks for a few of these...
I used one of the narrow pieces to bend the notch but I cheated a little, I cut shallow grooves in it to get a clean bend, I then threw a bead over it...
almost forgot to weld a nut in there for the bumpstops...
Boxing plates...
Other side tacked in...
elgemcdlf
Post by elgemcdlf »
I love you with all my heart but you broke my heart chopping your frame like that.
JG F100
Post by JG F100 »
elgemcdlf wrote:I love you with all my heart but you broke my heart chopping your frame like that.
I hated to do it too but I needed more clearance, I had about an inch and half between the frame and axle. Without getting into the bed floor its a necessary evil.
