72 F100 project, longbed to short conv, CV swap, 20s
JG F100
Re: 72 F100 project, long bed to short bed conversion
Post by JG F100 »
chet wrote:looks good! I am looking at doing the CV suspension as well. How do you know where to locate the lower rear mount?
I'll just follow what most do and fabricate a bracket onto the frame after its been lined up.
72 F100 - SWB conversion w/05 crown vic IFS, 8.8 rear w/disc, 20s, 360FE w/overdrive
Project Page: http://www.fordification.com/forum/view ... 22&t=37897
marvin2
Post by marvin2 »
looks good so far...keep up the good work and keep posting those pics!!!
What engine/trans are you planning on running? I have been thinking about the crown vic swap as well and keep going back and forth between wanting to run my current 302 or use the motor mounts from the new crossmember and running a modular 2V motor.
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
DavidJoe
Post by DavidJoe »
marvin2 wrote:looks good so far...keep up the good work and keep posting those pics!!!
I did the GM truck frame graft, and after wrapping it up heard about the CV, I think the CV is better, but too late for me on this project anyway, I'm running a 2V mod motor in the GM chassis, I think what you'll discover is; if the cross-member has motor mounts they may be too far forward or backward to use in the truck, however if you're considering the CV suspension then you're talented enough to use either engine, and make the appropriate mounts.
JG F100
Post by JG F100 »
I've been all over the map over what engine I really want but for now I'll throw the 360 back in there. I've thought about a stroker FE, a 460 or stroker, 4.6 or 5.4 3V or even a 5.4L Lightning swap. I've also got a 351W I've been saving for another project that i could use. It just depends on $$$
JG F100
Post by JG F100 »
A little update on the CV crossmember swap, I've got the holes drilled and suspension mocked up. I had pieces of 1/4" and 3/16" scrap I was going to weld together and make spacers for the top of the frame but I'm going see if I can find some 5/8" material somewhere. Also need to make the trailing arm brackets and box in the frame.
I'm debating on whether or not to cut the 94+ mustang joint and simply use the DD portion of the steering shaft. I can order the ujoint and shaft from summit or jegs but I might go look and see what I can find at the junkyard, not too crazy about the steering column either as its a column shift but welded up a long time ago. Its got a floor mounted shifter now.
JG F100
Re: 72 F100 project, long bed to short bed conversion (+CV Swap)
Post by JG F100 »
I've been chipping away on the CV swap little by little....
I made some brackets for the trailing arms.
Boxed in the frame...
Brushed on some POR15...
Put in down on all fours again... and yes those are ET streets on the front from my other car. I've been wheel shopping but I need to get
the sheetmetal back on to see how much offset is required. Thinking of 20s all around or maybe a 22/20 combo
rjewkes
Post by rjewkes »
so on the rack n pinion the gearbox is built into the cv's sunspension? or atleas part of the rack itself and bolted to the crossmember?
sorry for this question but never paid much attention to rack n pinion, thought it was just a fancy word for a chevies' steering gear box.
other question, will the cv front and rear accept a rotor designed for the 5x5.5 bolt pattern?
fuelly.com
69FLATBED
Re: 72 F100 project, long bed to short bed conversion (+CV swap)
Post by 69FLATBED »
Wow that's some project.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
sport71
Post by sport71 »
I like what you have done. very clean looking work
i hope that you can finish soon.
Those who do not learn the lessons of history, are doomed to repeat it.
marvin2
Post by marvin2 »
Your project is coming along great man! I am so stoked to try this CV swap myself. Any idea how much drop you gained in doing the swap up front?
JG F100
Post by JG F100 »
rjewkes wrote:so on the rack n pinion the gearbox is built into the cv's sunspension? or atleas part of the rack itself and bolted to the crossmember?
Yes the rack and pinion replaces the steering box and all the arms, center link, etc. I didnt look into it but I'm sure you could retrofit a rack and pinion in a stock i-beam suspension. The crown-vic is 5x4.5 and I doubt it could accept a 5.5 truck rotor, maybe it could be redrilled to 5x5.5?? I dont know... but there are a lot more wheel choices with the 5x4.5.
JG F100
Post by JG F100 »
marvin2 wrote:Your project is coming along great man! I am so stoked to try this CV swap myself. Any idea how much drop you gained in doing the swap up front?
I dont know for sure but its definitely got a rake to it now... I plan on cutting a coil or two after I get the engine back in there.
marvin2
Post by marvin2 »
That's pretty cool...this thing is going to be a sled when you are all said and done! Keep them pics comin'!
marvin2
Re: 72 F100 project, longbed to short conv. (+hydroboost)
Post by marvin2 »
Excellent work JG....
Looks like I will be doing a hydroboost setup as well. What are you doing about a proportioning vavle? Are you planning on running disc brakes in the rear as well?
I can't thank you enough for all the detailed pictures and write-ups. As soon as I get a garage, I am going to blow my truck apart and get started doing the same stuff.
JG F100
Post by JG F100 »
marvin2 wrote:Excellent work JG....
I'm going to try running without a p-valve and probably get an explorer rear-end w/disc .
