67 F100 Crown Vic suspension, Diesel engine, disc brakes
Fordnatic
Re: 67 F100 Crown Vic suspension, Diesel engine, disc brakes
Post by Fordnatic »
Hey Carcrafter,
Did you see the diesel mustang on the cover of the new (Jan) Hot Rod? Part of the power tour coverage. Also was a short blurb about a 1200HP bump.
55F100
miner3do
Post by miner3do »
:D good to see more young ppl around i got mine for my 16th birthday now im 18 and never geting rid of mine ever.
that 4 cyl turbo diesel has to be a ton of fun i liked the twin setup alot actually but that pro charger should be fun
1990 Mazda Miata 1.6 turbo
2010 Audi S4
1967 F100 4x4 4spd
carcrafter22
Post by carcrafter22 »
No I havent seen that issue but I will be looking for it now, thanks for the heads up.
I got to come home for the day from my job and played with supercharger placement but soon realized this will be so much easier thanks to the new engine thats on its way.
I couldnt do much so I decided to play with paint, I bought some olive green primer to see what it would look like and I have to say I am pretty happy with it. I like the 2 tone look with the wheels. I am thinking a nice olive green satin paint (not just primer) and either a very dark charcol grey (to go with the gunmetal grey wheels) or with the black thats on there right now. I couldnt move the truck out of the garage right now since the injectors are at sheids right now getting opened up but you can make things out, although the green is just a hair darker than it looks in the pics but not much.
I would like to hear your opinions on it.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
70shortwide
Post by 70shortwide »
new engine?
c'mon, spill the beans...
Looks good. Im a little more into gloss paint but I like the way that looks...
68CamperSpecial
Post by 68CamperSpecial »
I think the olive green with the gunmetal rims would look awesome. Very unique :thup:
Learning something new about these trucks every time I log-in
OldRedFord
Post by OldRedFord »
68CamperSpecial wrote:I think the olive green with the gunmetal rims would look awesome. Very unique :thup:
I agree.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
1967AceStroker
Post by 1967AceStroker »
I think if you painted from the center of the body line down that olive green, and above the body line black with those rims would look best. I think if it were all gloss it would look WAY better than flat.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
carcrafter22
Thanks guys, I think thats the paint I'm going with, I just need to pick the maker of the paint since I wont be staying with primer only. I am looking at ppg, HRF
OldRedFord
Fordnatic wrote:Hey Carcrafter,
Is this the same Mustang by any chance? There cant be that many diesel Mustangs.
http://www.dieselpowermag.com/features/ ... index.html
Tim
Fordnatic
Post by Fordnatic »
Yep, same one. The story mentions the Hot Rod Power Tour.
55F100
carcrafter22
Thats the Nitrous Express mustang. I know the guy that helped build it. It runs a duramax diesel engine with a few upgrades, gets awsome mileage 35mpg, and runs in the 9's down the quarter miles and the owner drives it all over, try that with a gas motor LMAO!! I keep telling people diesels are the way to go and alot of them just look at me funny, its cars like this that prove my point.
carcrafter22
Time for an update. I have been gone since november 8th working out of town but I made it back finally and started working on the adapter plate to mate the 5R110 5spd auto to my isuzu diesel. I am taking a different aproach than the IDS kit. The IDS (isuzu diesel swapper) kit uses your stock manual flywheel drilled to accept a large spacer to mount a chevy flywheel and an adapter ring that bolts to the stock isuzu flywheel housing. I am currently using the IDS kit on my truck and it is a fine kit but there are a few problems with it. First it only comes to fit the chevy bolt patter. Second it uses 2 flywheels while this is fine for 99% of people and has worked well for me so far but when I am turning 5000rpm going down the drag strip I really dont want to have 2 flywheels turning that rpm by my feet. Third the distance from the block to trans mount is very far with this setup, I forget what it is right now but I think its around 6 or 7 inches.
With my setup I am using my own custom flyweel bolted to the isuzu crank and an aluminum spacer and adapter plate that bolts directly to the isuzu engine block, distance from the block to the trans 2inches. This will make me feel more comfy going down the track and turning big rpm not to mention I can now set the motor about 4 inches further back in the truck for better handling and weight distribution. The other bonus to this setup is a small weight savings, I still need to weigh things so I dont want to say anything official yet but I think this will save around 30 pounds or so (I may be wrong since that is a guess at this point but cast iron weighs alot more than aluminum).
I still have a good bit of work left but here are a few photos to show the progess.
Stock isuzu flywheel on the left and on the right my custom flywheel made to my own specs.
Here is my head fabricator hard at work, shes drilling the holes so she can start tapping the 7/16" threads to bolt the tranny to the adapter.
Here is the actual adapter itself, this is made from 1" 6061 aluminum plate.
Here is the adapter bolted to the spare 5R110 trans case I have for mock up (found it at the local scrap yard for $10). Its hard to see but there is an almost perfect 3/16" gap all the way around the bellhousing and amazingly I got it all very straight considering I cut it out with an 18 tooth carbide blade on a skill saw then cleaned it up with a 4.5" 36 grit flapper wheel.
CO684X4
Post by CO684X4 »
:thup:
CO684X4
Post by CO684X4 »
What backspacing are you running with the new wheels? Do they clear the front caliper bracket or did you have to run a spacer?
averagef250
Post by averagef250 »
Randy, nice work, but I'm a little curious about something- Are you really putting this new adapter together with a benchtop drillpress, skilsaw and grinder with a flapwheel or do you have access to appropriate equipment that you aren't showing?
