Saw these trucks on Craigslist today. I don't know anything about them, but the price seems cheap enough. The first two look like pretty solid trucks.
https://greensboro.craigslist.org/ptd/d ... 63307.html
https://greensboro.craigslist.org/ptd/d ... 52824.html
https://greensboro.craigslist.org/ptd/d ... 67071.html
Cheap Trucks on Craigslist
- basketcase0302
Re: Cheap Trucks on Craigslist
Wow...the bed on the 3rd one is like perfect shape, (due to the camper shell protecting it) being worth his asking price alone.
And all three dashes are unbelievable too!
They have 360's. Prevailing internet opinions says they are worthless.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
- MadJoe
I'd like to see these prevailing opinions, it'd be fun to set them straight. The 360 block is identical to the 390, so if you were needing to rebuild it like these appear to need, just use 390 parts. The only worthless FE block is one that can't be fixed, and even then it's worth scrap money because it's heavy.Bill Ramsey wrote:They have 360's. Prevailing internet opinions says they are worthless.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
MadJoe wrote:I'd like to see these prevailing opinions, it'd be fun to set them straight. The 360 block is identical to the 390, so if you were needing to rebuild it like these appear to need, just use 390 parts. The only worthless FE block is one that can't be fixed, and even then it's worth scrap money because it's heavy.Bill Ramsey wrote:They have 360's. Prevailing internet opinions says they are worthless.
I have 3 360 engine here, 2 of them run. Can't give them away.......
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
