tire size
67 short box
tire size
Postby 67 short box » Sun Mar 18, 2018 9:47 am
cant decide what size tires to put on the 67. I don't know what came on it new. just a cruiser, no hot rod. 240, 3 speed, 370 ratio. shes wound up pretty tight at 70 mph. stock wheels now, may change to 7 or 8 inch wheels also. .thanks
Ohiotinkerer
Re: tire size
Postby Ohiotinkerer » Sun Mar 18, 2018 10:43 am
If its the same as my 68 today's equivalent would be a 235/75-15 for stock. I bought a set of Wheel Vintiques 62 series 15X8 steel rims and moved up to a set of 31-10.5 Mastercraft Courser LTR's on mine to drop the RPM's a little but I'm running a 3.25 rear end - with that combo im turning about 2600 at 70 MPH. You may want to look at a gear change to really get it down to where you want it because you're still gonna be up there with that 3.70 in there........... I have some photos in my gallery of what they look like mounted if that helps.....
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
67 short box
Re: tire size
Postby 67 short box » Mon Mar 19, 2018 12:25 pm
photos helped
thanks
jzjames
Re: tire size
Postby jzjames » Mon Mar 19, 2018 11:06 pm
For your SBF w 240 you want to keep the 3.70. 8)
Also 235/75/15
67 short box
Re: tire size
Postby 67 short box » Tue Mar 20, 2018 2:24 pm
i just got two 235x70's waiting on two more wheels.
wish I would have got the 235x75.....
Who is online
