Steering Column
No tech discussion, please
Twisted_Steel
Steering Column
Postby Twisted_Steel » Fri Feb 23, 2018 3:37 pm
For those of you have done the swap, will a 74-79 column fit with no issues in a 69 truck? I know the plug may be different because the emergency flasher switch on mine is in the glove box. I can rewire the plug to make it work, just wondering about the shaft length and mount holes lining up.
Thanks in advance
Re: Steering Column
Postby sargentrs » Fri Feb 23, 2018 4:55 pm
This is about installing a tilt column but should answer most of your questions. http://www.fordification.com/tech/tilt.htm
1970 F100 Sport Custom Limited LWB, 302cid, 3 on the tree. NO A/C, NO P/S, NO P/B. Currently in 1000 pcs while rebuilding. Project thread: viewtopic.php?f=22&t=59995 Plan: 351w, C4, LSD, pwr front disc, p/s, a/c, bucket seats, new interior and paint.
1964 Ford Fairlane 500. 289/Cruise-O-Matic, A/C, P/S.
Twisted_Steel
Re: Steering Column
Postby Twisted_Steel » Sun Feb 25, 2018 6:24 pm
Thanks Sarge.. I was in a bit of a pickle. I couldn't get good enough reception to get past the forum section
Return to “General Discussion”
Who is online
